Author Topic: Almost done removing cylinderhead  (Read 2281 times)
126bis1997
« on: April 19, 2009, 10:03:30 PM »
The head seemed to be stuck. However, I managed to be getting it out, just a few millimetres bit by bit.
The original problem was when I topped up the radiator, water seemed to be going up the carburator.
Question: 1. Do you experts think that if I face the head and change the gasket, the problem would be solved?
              2. Can you give me the torque for fastening the head?
              3. Is there anything else I should know?
I managed to clean the carb with a solvent specially adapted and aerosolve cans and found it very good.
Thank you in advance to any replies
PETER
« Last Edit: April 20, 2009, 07:12:33 AM by 126bis1997 »
Re: Almost done removing cylinderhead
« Reply #1 on: April 20, 2009, 09:36:14 PM »
Hi Peter, Get the head pressure tested if thats O.K. have it skimmed flat, the head torque settings are in the download section ;)
http://club126uk.co.uk/index.php?ind=downloads&op=entry_view&iden=7
126bis1997
« Reply #2 on: April 21, 2009, 08:58:42 PM »
Thanks for the reply. Did not skim the head, just cleaned because it was perfectly in still good shape. I did not hone the valves but i only did the setting of the valves. I put everything back including a new gasket. I did the torque as mentioned on the download of this site and today .. this evening i took my Bis for a ride :) and everything seems ok.
PS: the sound of the engine is smoother and with a particular whistling sound but very faint.
Thanks to this site i never was a mechanic but now I am to my own car ;) the wonderful Fiat 126 Bis.
Thanks all,
Peter
Cheers!
« Reply #3 on: April 21, 2009, 10:15:40 PM »
Good news :salute: Just thought i would mention did you bleed the the cooling system through the tube mounted on the heater box under the front bonnet ??? also if you still have the thermostat in, take it out [-/ Have fun!
126bis1997
« Reply #4 on: April 22, 2009, 08:29:51 AM »
YES I did bleed the cooling system and put 4.8lt as described on the downloads section.
And also there was no thermostat so I left it whitout it since summer is on its way.
Thank you so much I owe this site a lot! [-/
Cheers Pete
