Author Topic: Gearbox Part Identification - please take a look!  (Read 2095 times)
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
« on: April 18, 2009, 07:14:18 PM »
Hello all,
The time has come again to spend the waking hours of my life (when not at work) outside in the sunshine attempting to fix a Fiat 126. I am now in the process of making one good gearbox out of 2 slightly knackered ones, and when dismantling the current one, I tipped it to one side and a small metal tic-tac looking thing rolled out. My questions are,
1) Is it supposed to be in there, and
2) What is it and where does it live?
In the picture obviously are the retaining ball bearings for the selector rods and the other oval metal bits which go between the rods, but I don't recall seeing this smaller one in my last gearbox!
Any ideas chaps?
-Simon
Re: Gearbox Part Identification - please take a look!
« Reply #1 on: April 18, 2009, 10:04:03 PM »
i will look in my workshop manual for what it is but you will have to wait until tommorow for me to do it.
« Reply #2 on: April 19, 2009, 12:23:58 AM »
A guess... it may be connected with the indents on the selectors.
rockchevy85
« Reply #3 on: April 19, 2009, 08:45:46 AM »
Thanks for the diagram, Chris.
It certainly looks like 891631....the picture suggests it would be in contact with the lower 355301, but I thought the 2 larger oval ones were oval because they were in contact with the indents in the selector rods.
rockchevy85
« Reply #4 on: April 19, 2009, 10:45:19 AM »
In fact, having taken a closer look, this diagram is indeed perfect. The centre selector rod 4107998 has a small hole right the way through, which the tic-tac fits inside. Not only has this answered my question, but it may also explain some of the problems I was experiencing the last time this gearbox was fitted to the car.
Thanks Chris, and everyone who thought about it!
« Reply #5 on: April 19, 2009, 11:15:19 AM »
 :) Hi Simon , I went through the same process as you are doing a couple of years back but I had 4 boxes , all of which had different faults apart from a couple of knackered layshafts. The Haynes manual makes it pretty easy . I just stripped them , cleaned everything up , kept the main castings diff unit & main shaft sets together. Then reassembled using the best bits & ended up with two perfect gearboxes. I am going to repeat the process with 3 Fiat 500 boxes in the near future. Got them on eBay , one for £2.75 & the other 2 for £5 each  :) Opening up one of these boxes is a bit like opening a Kinder Egg , you never quite know what to expect. Any way I kept all of the bits that were not busted & have helped out a number of people over the last few years so if you find you need a part I may have it up in my shed. So if you need  :help2: let me know.
rockchevy85
« Reply #6 on: April 19, 2009, 03:35:36 PM »
Hey thanks Rusty. I too have a box of bits now, though I'll keep that in mind in case I need something else.
The car is a BIS and the gearbox was knackered when I bought the car. Replaced the layshaft bearing and bought the gearbox repair kit from ebay but after a couple of stripdowns it started staying in second gear and allowing the gear linkage to pop to the wrong side of the selector rods (maybe because of this missing tic-tac?)
I picked up a cheap A/C gearbox from ebay and swapped the bellhousing etc. Ran fine until recently when it started to make grinding noises when stationary. Today's exercise should see a good box, as I've used the original BIS box with new gears and bearing, and the selector rods and one of the synchro rings from the A/C box to make one uber box. Still need to do a head gasket change before the whole lot goes back in the car, but I'll post my results here!
Thanks again,
Simon
