Author Topic: New Manifolds  (Read 2869 times)
Eklipze3k
New Manifolds
« on: April 14, 2009, 10:14:04 AM »
Hi all,
Was gonna pop my new exhaust on now that the car is MoT'd, but in trying to remove the old one from the manifold I've managed to shear a bolt and now can't get it out.  :oops:
Considering they're pretty cheap I quite fancy getting a pair of new ones anyway from Chet, I notice he's got a set of nuts/bolts to go with it as well (E-bay item 200285193228). Is it worth me getting this too, and what are the semi-circular metal plates for?
Re: New Manifolds
« Reply #1 on: April 14, 2009, 12:30:58 PM »
 Getting the manifold of the cylinder head is even worse, as the bolts tend to break in the head.
Eklipze3k
Re: New Manifolds
« Reply #2 on: April 14, 2009, 12:42:29 PM »
Getting the manifold off the cylinder head is even worse, as the bolts tend to break in the head.
:o Don't tell me that!! I already managed to get one out and was assuming that the rest of them would be ok  :cry:
Re: New Manifolds
« Reply #3 on: April 14, 2009, 01:12:42 PM »
 Maybe it is just me ??? Tried WD-40, heating the bolts up, doing it as careful as I could, but the bolts still broke. It is always the front ones for some reason...
 Good luck!
Eklipze3k
Re: New Manifolds
« Reply #4 on: April 14, 2009, 01:31:17 PM »
Now that you've worried the hell outta me thanks :P
So, the important question tho, is should I get that nut and bolt kit too and - if so - what are the semi-circular bits of metal for?
Re: New Manifolds
« Reply #5 on: April 14, 2009, 04:24:34 PM »
Those bolts into the head do have a habit of locking in & I tend to remove them only when absolutely necessary. If your engine is running then getting it up to temperature before you try and remove them sometimes helps but don't burn yourself. If you can get to the back of the sheared stud you can drill it out 8.5 mms then just put a bolt through but you will need to file a smidge off the side of the bolt head so it sits right. Many of the new manifolds have plain holes anyway & do not take studs plus a new manifold today will look pretty much like the ones you have now 6 months down the line so you might just as well love the ones you are with. The semi-circular bits are original tab washers which I find a bit of a pain in the bum  & just use a spring washer and never had any problems. If you are thinking long term I would go for stainless fixings in that area to prevent future problems & ease of maintenance.
Buy the way , just for the record , Chet is a lady  :D
Eklipze3k
Re: New Manifolds
« Reply #6 on: April 14, 2009, 04:58:01 PM »
D'oh!  :oops:
nrg19uk
Re: New Manifolds
« Reply #7 on: April 14, 2009, 05:40:27 PM »
and the nut and bolt kit from them doesnt contain the bolts to hold the manifold to the head! ive just had the kit from them..... goto a hardware shop they will do some lovely stainless ones (like rusty said) dont over tighten them aswell you will strip the thread in the head like i did hehehe.
Neil gargaro
Re: New Manifolds
« Reply #8 on: April 14, 2009, 06:36:02 PM »
 ... I notice he's got a set of nuts...
 Well, hopefully not. Now we all now she is a lady... ;)
Re: New Manifolds
« Reply #9 on: April 15, 2009, 06:13:40 PM »
Get the brass nuts. When tightened-up they cover the whole of the thread and help stop the rust from getting to the thread on the manifold.
The engine runs too hot for copper slip, wish I still had some nickel slip as I used nickel slip on my xs1100 exhaust bolts and it works a treat. Still on it now 10 years later and it runs hot!
The copper slip I put on the fiat bolts burnt off! :oops:
Eklipze3k
Re: New Manifolds
« Reply #10 on: April 30, 2009, 12:52:13 PM »
 :cry: :cry: :cry:
Got new manifolds, bolts and gaskets and set to work this morning but oh no, it's 25 years old and Italian so of course it wouldn't be as simple as replacing parts!
First off, here's the old ones. The left one is the one from the back of the engine and was still usable, the right as you can see is goosed.
However, here is where the real fun starts! The bolt on the right is what was holding the goosed manifold to the head and is clearly massive!!1!
I can only assume that at some point someone threaded the head and had to get it re-tapped. So now I have to enlarge the holes in the brand new manifold to accomodate for this  >:(
On the plus side, everything fits perfectly to the exhaust, just got to attach it to the car now  :oops:
Tomasz
Re: New Manifolds
« Reply #11 on: April 30, 2009, 10:29:33 PM »
Glad yours fitted ok.  When i fitted new manifolds with a new exhaust the manifolds were not very good copies and i had a fair bit of fiddling to get it all to line up!
Eklipze3k
Re: New Manifolds
« Reply #12 on: May 07, 2009, 10:00:54 AM »
Got it drilled out the other day and is all now fitted properly, had to fabricate a lower mount as the exhaust itself was sitting a little low but it's sturdy enough, and if anything is even louder than the last time! I'll get a new vid when the rain stops and a pic of the fabricated mount :)
