Author Topic: Spare Keys & 'What Is This Light?'  (Read 1771 times)
toby-toby-two
« on: April 10, 2009, 05:33:28 PM »
Hi there, I'm wondering if someone can help me. I'm in need of a spare set of keys for my little one but cannot get hold of them anywhere - Timsons and some other local chains can't help so I'm stuck - any ideas someone?????
Also, can someone tell me what this light is? It stays on constantly so I'm not sure if the sensor on it is knackered? If so, is it easy to replace/resolve?
Thanks in advance.
Re: Spare Keys & 'What Is This Light?'
« Reply #1 on: April 10, 2009, 05:50:39 PM »
water level light sensor is on the bottom of the radiator bottom left i beleive some times the wires just come off...
« Reply #2 on: April 10, 2009, 06:14:16 PM »
Have you checked the water level ??? With the ignition on try filling the expansion tank up until the light goes out, if the water starts to pour out of the filler neck, remove the nearside grill and you will see the black expansion bottle, if you look to the right you will see two wires that are connected to the water level sensor, not sure how it comes out ???
« Last Edit: April 10, 2009, 06:42:21 PM by Pete126 »
subvert73
« Reply #3 on: April 10, 2009, 07:05:32 PM »
Hi Mate,
Keys are available from your local fiat dealer, they come pre-cut and are quite expensive but unfortunately the only option.
Steve.
« Reply #4 on: April 10, 2009, 08:40:54 PM »
Hy + what the others said + the water indicator is where pete said, on the expansion tank, it comes off just by twisting it counter clockwise, just be careful, as the little thingy inside tends to fall of into the tank, and is a pain in the neck to get out (i know, mine is still in there :P )
