Author Topic: Reverse lights  (Read 2800 times)
Eklipze3k
Reverse lights
« on: April 07, 2009, 09:55:17 PM »
Neither of them come on, where should I start?
Cheers!
Re: Reverse lights
« Reply #1 on: April 07, 2009, 10:24:51 PM »
Bulbs,fuse, switch, wiring, new car ;D
Eklipze3k
Re: Reverse lights
« Reply #2 on: April 07, 2009, 10:33:23 PM »
I'm 99% certain it's not the bulbs, as I find it highly unlikely that both would pack up at the same time. I'll check fuse etc asap as I want to have him MoT'd before the end of this week but everytime I think I'm ready the electrical gremlins appear again!
Re: Reverse lights
« Reply #3 on: April 07, 2009, 11:04:22 PM »
you can always unbolt then and fix em later.. they aint mandatory for the mot.... ;)
Re: Reverse lights
« Reply #4 on: April 07, 2009, 11:15:06 PM »
hes got the special edition rear lights by the sounds of "they both" in the last statement . its also possible the reverse switch connection has come out from the gearbox.
Re: Reverse lights
« Reply #5 on: April 07, 2009, 11:19:16 PM »
bums my idea wont work then......sounds like its out wth the test lamp and try each part of the circuit until you find it had the same prob with my fog light turned out to be the wire from the fuse box to the switch broken down inside and I had to run another wire through.......
Re: Reverse lights
« Reply #6 on: April 08, 2009, 05:33:07 AM »
It could be just a bad connection with the bulb, i have probs with the brake lights every now and then, cos the bulb slot rusts.. :P oh, and check if the rear lights are connected at all, i have a feeling that they were installed additionally, its possible they were not connected in the first place...
Eklipze3k
Re: Reverse lights
« Reply #7 on: April 09, 2009, 01:30:37 PM »
From what I can see, it looks like I don't actually have reverse lights! Bearing in mind this car as already been for an MOT and this wasn't picked up - the lenses are there, as are the plugs from the back of the light cluster - but they're not (and don't appear to have ever been) attached to anything, so there was me worrying over nothing!
Re: Reverse lights
« Reply #8 on: April 09, 2009, 03:51:48 PM »
I dont get it? you got the lenses, do you have the metal piece that goes into the lens?
if you do, why not connect it? rev lights make driving easier you know  :oops: :D
Eklipze3k
Re: Reverse lights
« Reply #9 on: April 09, 2009, 05:48:56 PM »
Sorry, I don't think I explained very well  :oops:
The lenses look identical to those, and have the plug coming out of the back but there is nothing in the car to plug that in/onto.
Re: Reverse lights
« Reply #10 on: April 09, 2009, 07:00:35 PM »
ooo, well, take some wires, and wire it up to the gearbox... shouldnt be too difficult... ;)
Eklipze3k
Re: Reverse lights
« Reply #11 on: April 09, 2009, 08:31:48 PM »
I wouldn't have a clue where to start  :cry:
landyman
Re: Reverse lights
« Reply #12 on: April 09, 2009, 09:23:52 PM »
basic wiring not rocket science or scary 2 ways to aproach this if you have apropriate switch on gearbox identify a suitable live feed fuse this take this to gearbox switch take other side of switch to pin terminal of bulb holder the body terminal of bulb holder goes to earth.  another option is to take a fused supply to the bulb centre pin and the body of the bulb connector goes to a single terminal gearbox switch which earths internaly when you select reverse. use a suitable wire gauge and an 8amp fuse any problems e-mail me for tel.no. if you dont have gearbox switch you can fit one on dash ect. remember to fuse any accessories!!!  costs pennys saves fires
