Author Topic: fiat panda  (Read 2921 times)
nrg19uk
fiat panda
« on: October 20, 2005, 11:10:41 PM »
anyone know if i can have electronic ignition on my fiat panda 750l. any sites or anything that may help
cheers
Neil gargaro
fiat panda
« Reply #1 on: October 20, 2005, 11:39:39 PM »
I know the later pandas (fire engines) with fuel injection are fitted with electronic ignition distributors. That is probably your best root? Should fit with a bit of a wiring alteration you will probably have to use the later coil as well.
fiatfsm
fiat panda
« Reply #2 on: October 21, 2005, 04:19:18 PM »
why do you want it though, conventional points work well enough, they are easy to replace and when they go wrong its cheap to fix. Electronic ignition will never be 100% reliable and when it packs up you need a whole new unit. stay with the points system.
