Not a Motorhome, but i towed my newly acquired BIS to Rugby from Chippenham some 120 miles on an A-Frame behind my Shogun yesterday. I borrowed the A-Frame from a friend, i think he said it was about £125 about a year ago. You can't reverse with this method and all four wheels are the ground so you add mileage to the car. The Front tyres scrub when you turn full lock, but considering the cost and how little you would have to do this other than when Parking for the night (when you would have already disconnected the vehicle from the Motorhome) its a small disadvantage. The car towed beautifully, as well as any trailer i have used previously. Once set up the frame would only take about 15 mins to fit tops. With the 126 being faily low you may need to jack it up and fit axle stands first, I did, but if you chose not to you could save 5 minutes each time easy.
