Two rubber vacuum pipes should connect to the solenoid valve which is mounted on top of the r.h. inner wheel arch just to the right of the carb.
High speed cooling fan operation simultaneously puts a positive supply onto the solenoid valve which opens the vacuum line which, via a system of levers, creates an increased throttle opening. This is to generate more engine rpm to compensate to meet the additional electrical load of the cooling fan. That is the theory. In practice I have found that, because of wear in the linkage, it does not work. Certainly it didn't on my car and engine running did not suffer so I sealed off the ports by fitting a short lengths of tight fitting rubber tube with tight fitting bolts to plug off the air passages.
Banjo.
