Author Topic: bis starter motor - slipping? where to buy new one?  (Read 2340 times)
fightingtorque
« on: March 14, 2009, 09:03:27 PM »
Hi guys,
BIS is giving me some trouble. The starter sometimes can be heard spinning but not turning the engine over, or else it turns it over fine but if the engine fires once and doesn't properly start, the same thing happens, starter just spinning.  I thought maybe it wasn't engaging the flywheel but having taken it off and taken apart, it seems that if the solenoid wasn't pushing the pinion into engagement it wouldn't make the motor contacts either.
There is a kind of clutch/ freewheel arrangement on the pinion, presumably so that once the engine starts  the pinion will freewheel rather than spinning the motor too fast.  Fiddling it back and forth, it seemed possible to defeat the freewheel action sometimes.  I gave it a shot of lithium grease and then it seemed to work properly , freewheeled one way but not the other.  But put it back in the car and the problem is still there.
Is this a common failure mode on these?
Can it be fixed?
Where can I get a new starter - looked through the internet but all I saw were aircooled ones (and expensive!) .  Mayber this is an ordinary spec starter I can pick up in any motor factors?
Mainly I have been busy preparing my Cinq sporting for its MOT, which is turning into a bit of a restoration.........
Cheers,
Gav
Re: bis starter motor - slipping? where to buy new one?
« Reply #1 on: March 14, 2009, 09:22:16 PM »
It is a common fault mine did the same, i bought the solenoid kit and that sorted it out.
banjomandolin
« Reply #2 on: March 16, 2009, 12:25:00 AM »
How much was your solenoid kit and from where ?. I think I may need one for a 133.
Banjo
John Clark
« Reply #3 on: March 16, 2009, 09:14:15 AM »
Gav Ive got 2 spares (tested and working) and as you know I'm local to you......
« Reply #4 on: March 16, 2009, 06:39:03 PM »
Banjo
They are 48euros from axel gerst + postage.
I got mine from [email protected]  I think it was about 25euros + postage
fightingtorque
« Reply #5 on: March 16, 2009, 10:30:22 PM »
cool.  probably safest to meet in a pub sometime in case it starts snowing again.
