Fiat 126 Chat
rear wheel barings. How
Pages: [
Topic: rear wheel barings. How (Read 2017 times)
markie
1982 original bodywork no rust no welding
on:
March 14, 2009, 04:36:22 PM »
Hello peeps, Just done the front barings but the back are weird! Unbolted the driveshaft to reveal the nut that hods the hub together and it's so darn tight i cant even shift it with an 18" knuckle bar. Does it undo pushing the car forward or back?
Subscriber VIP+
Re: rear wheel barings. How
Reply #1 on:
March 14, 2009, 05:22:24 PM »
</8 It is a bit of a crazy set up for some reason. I had a two foot bar on mine and pulled it off the jack trying to loosen it. Just got my arm out in time. Also if you fit a new bearing kit you have to compress the collapseable spacer which is pretty much impossible with any normal equipement so I have just left it out at the moment on one side. I had a word with an experienced mechanic and he showed me a torque converter wrench. It was about 18" long but had a 4 to 1 torque ratio so was equivelent to a socket on a 6 foot bar
: When I put a new bearing in the other side I recycled the already compressed spacer with no problems, once I got the bloody thing undone that is !
markie
Reply #2 on:
March 14, 2009, 09:53:10 PM »
You know what, I think I can live with a slight rumble from the back. I'll just put some speakers in the back too and turn up the stereo.
Subscriber VIP+
Reply #3 on:
March 15, 2009, 07:37:06 AM »
[-/ Having studied the bearing arrangement I can not see what the function of that spacer is . With it removed it just becomes a typical double taper roller bearing set up. I have covered a couple of thousand kms & no problemo
markie
Reply #4 on:
March 15, 2009, 06:56:03 PM »
I've already got a compressor so I'm thinking of getting one of those air guns, perhaps that hammer action will shift it?
Reply #5 on:
March 16, 2009, 09:44:10 AM »
i have used a method of suitable spanner /socket on the hub nut then a length of scaffold pole or gas pipe then inserted into that a 6ft long weight lifting bar it does the job very well , remember the longer the lever the easier it gets ..
markie
Reply #6 on:
March 21, 2009, 09:50:10 PM »
And I guess you chain the car to a suitable building or inanimate object to stop it from rolling towards you LOL.
Reply #7 on:
March 23, 2009, 09:28:28 AM »
if not you can always remove the complete hub assembly and put it in a vice
markie
Reply #8 on:
March 23, 2009, 06:11:23 PM »
I'm quite liking that idea! I'll take a look at the weekend [-/
Pages: [
Fiat 126 Chat
