Author Topic: Unleaded and Timing  (Read 2128 times)
custardboy
Unleaded and Timing
« on: February 24, 2009, 09:10:38 AM »
It's me again seeking more help.
My 126 is running a lot better I have managed to keep it going for more than a week now so fingers crossed!
I have had the cylinder head overhauled and converted for unleaded, I have serviced the carb with new gaskets, seals and jets.
What should I set the static timing to?
I had it advanced too far originally as it would not run unless mixture screw was fully in but was then running too rich I now have it at about 12 degrees BTDC with carb set up properly but whilst it runs well it is getting very hot and occassionally runs on (pre-ignition).
Do I retard the ignition for running on unleaded or advance it?
Should I use an additive such as an octance booster?
I want to go back to using it on the motorway but am afraid that any sustained high speed (relative term) driving my blow my angine to bits again!
Re: Unleaded and Timing
« Reply #1 on: February 24, 2009, 07:02:35 PM »
I would set the static ignition back to standard spec which is 10 btdc, Test the centrifugal advance that should read 18 btdc, by advancing the ignition it gives the impression that its quicker off the mark but you tend to loose it at the top, it also creates more heat.
As you mentioned its running on which is classic too much advance.
custardboy
« Reply #2 on: February 25, 2009, 01:29:34 PM »
Cheers Pete I will give that a go.  Overall it is running much better now after all my attempts to break it.  I will take some photo's to put up in garage section, not much of looker but I like it.
I have one last problem with the carb this time.  When I overhauled the carb I found the slow running jet was loose for some reason.  I fitted a new o ring to this when reassembling the carb, however I find I have an annoying flat spot as I initially open the throttle unless I unscrew the slow running jet about 2 turns ?
Any ideas on this one?
« Reply #3 on: February 25, 2009, 03:52:16 PM »
Could be some thing to do with the timing, check the points first, then the ignition timing, and then the carb if its not improved :)
