Author Topic: Sh1t brakes  (Read 1514 times)
subvert73
Sh1t brakes
« on: February 21, 2009, 05:17:09 PM »
The brakes on my 126 are useless to say the least, if I opened the door and put my foot onto the road it'd be just as effective!
The dreaded MOT is looming over the horizon so I thought it would be a good idea to sort them out. The pedal felt really spongy, as if there was some air or moisture in the system. Rather than just bleeding them I decided to replace all the fluid.  So I've just spent 2 hours flushing all the old fluid out and replacing it with brand new.
Went out for a test drive and they're just the same as before. :(
I know that 126s are renowned for having bad brakes but mine do seem excessively bad. I'm now thinking that maybe the drums are slightly off round? I've got the early drums on my car (with the wheel bolt holes right on the edge). Has anyone else had problems with drums going out of shape? I'm reluctant to buy new drums because I want to replace the hubs with the later type in the near future if I can find some second hand. Anybody got a set that they want to flog?
Steve.
Re: Sh1t brakes
« Reply #1 on: February 21, 2009, 07:16:12 PM »
If the drums are oval you will be able to feel this when you push the pedal, it will bounce back and feel like a vibration.
If when you push the pedal and it feels smooth the drums are O.K.
Its possible to get air trapped in the master cylinder, when you bleed the brakes undo the brake pipe nut (out) on the master cylinder a couple of turns and get some one to push the pedal down until the fluid starts to squirt out and then tighten the nut up when the pedal is down on the floor.
Start bleeding with the nearest wheel cylinder to the master cylinder Yours being LHD the nearside front then the offside front, then to the back.
If this does'nt sort out the problem it could be sticking wheel cylinders.
If the MOT is coming up you can take it for a test a month before, and they will tell you if the brakes are in balance or not, Hope this helps :)
Re: Sh1t brakes
« Reply #2 on: February 22, 2009, 01:59:30 AM »
hi steve you might find that the overall wear of the drums have gone past their limits and so your brake shoes do not exert enough pressure giving you rubbish brakes , have you had the drums off as you really need to look at the condition of all the components , as for hubs i still dont know if i can find a home for my on hold project if i cant find one then you can have the hubs .
