Author Topic: Unleaded cylinder head  (Read 2258 times)
« on: February 17, 2009, 11:02:37 PM »
 Just a question. Does anyone know, if any of the late air cooled engines were fitted with unleaded cylinder heads? When did they stop the production of the air cooled engines? ???
MaLi
Re: Unleaded cylinder head
« Reply #1 on: February 18, 2009, 06:52:23 AM »
The unleaded cylinder heads were fitted to aircooled made after mid 1991 - I had an info on engine number when the switch was made but cannot find it at the moment.
I was using pre-1991 head on unleaded and never had any problems - but I didn't do a high millage.
I think the only changes that were made for the unleaded head was the material of valve seats.
« Reply #2 on: February 18, 2009, 07:00:47 AM »
 Thanks for the info MaLI [-/ If you find the info for the engine numbers, respectively the head just post it on here.
Eklipze3k
« Reply #3 on: February 18, 2009, 07:47:20 AM »
Is there any easy way to tell if a conversion has been made? I've not drive my '83 aircooled much yet and never thought to ask the seller  :oops:
« Reply #4 on: February 18, 2009, 11:02:53 AM »
well some say that due to the head being made of alloy it should have hardenned valve seats already but thats all not true , you can run easily on unleaded the rules usedto be every fourth tank fill with leaded but as its not available just use a good lead replacement additive i run without chucking it in from time to time and over a couple of years have not noticed any problems.
Eklipze3k
« Reply #5 on: February 18, 2009, 11:05:44 AM »
Thanks Mick  [-/ Are additives quite readlly available?
« Reply #6 on: February 18, 2009, 12:48:47 PM »
I had a spare head fitted with new valve seats as a precaution and it was not that expensive with only 4 valves but to be honest I have never heard of anyone running into major problems with the original set up plus it is so easy to check the valve clearances on a 126 that it is no problem to monitor the tappets.  :D
« Reply #7 on: February 18, 2009, 02:48:17 PM »
additives are found in any halfords , or auto shops.
