Author Topic: loss of power on hills  (Read 2256 times)
ianfromcumbria
« on: February 11, 2009, 12:40:51 PM »
I'm new to 126 ownership and I know they do lose power uphill anyway, but this seems to be extreme.
On a long straight the other day, the car started to splutter and I pulled over. I put it in neutral and floored the accelerator, but the revs came very reluctantly, and not at full rev. After about 10 seconds it seemed to clear and revved normally so I continued on my journey. But I couldn't get it above 55mph, even on a slight downhill, and when I came to a slight uphill it really lost power and went down to 40mph.
I've had the car for about 2 months and the first thing I did was to get it serviced and checked over by a mechanic. Until now I've managed to get it up to 70mph max on a long downhill straight and sit at between 55 and 60 as a matter of course.
What could be causing this loss of power?
Re: loss of power on hills
« Reply #1 on: February 11, 2009, 01:46:58 PM »
lol the engine :D
Im not sure if you have a bis or air cooled, but it all depends on so many factors, how bad was the slope, is your carburetor OK, ignition timing, fuel delivery, head gasket, wind speed :) etc...
I know you said you had it serviced, but very few mechanics know how to service these old engines, try working on it yourself, you might not get it right the first time, but when you eventually learn, there's no stoppin ya...  ;) (this is how i get on... :P )
ianfromcumbria
« Reply #2 on: February 11, 2009, 02:46:52 PM »
I know - I need to have a crack at the mechanics myself. The slope wasn't bad and it really seemed to die. I'm just wondering if it's the fuel pump. It's a BIS and whoever had it before me replaced the original cam driven fuel pump with an electric one. It makes a few clicking noises when you first turn the ignition on and the revs go up and down for the first few seconds. It could be on its way out.
If anyone can point me in the direction of a handbook/idiot's guide which might give me a bit of ammo to tackle the mechanics myself, it would be much appreciated.
« Reply #3 on: February 11, 2009, 05:30:46 PM »
I had a rapidshare link to a handbook round here somewhere, cant seem to find it, ill upload it again  ;)
i know i had problems similar to yours, my fuel pipes were old, and cracked in a few places, every time id go up hills it would start jerking and slowing down, cos the pump started to pull in air thru the cracks, once i replaced the pipes the prob was solved. Try checking the pipes just in case ;)
« Reply #4 on: February 11, 2009, 06:09:29 PM »
ianfromcumbria
« Reply #5 on: February 25, 2009, 03:47:27 PM »
I've been away on my hols. Thanks for the files - I'll take a look at them
