Author Topic: Backfire?  (Read 3697 times)
Backfire?
« on: February 07, 2009, 11:46:02 AM »
 Hi guys. Thought I ask here again before start to muck about with it. Car is backfiring when I lift off. Picking up revs nicely and running smooth when revved up. Do you think it is the fuel supply?
 Haven`t even driven it yet cause of problems with the dynamo. Had the engine in out, all cleaned resprayed, new oil, recon dynamo and new regulator... Put it all back and it wasn`t charging. Faulty dynamo, so I had to take out again(what a pain in the back side...) Well got it back yesterday, so going down to the garage and hopefully we can take it out for a spin today.
 Anyway back to my original question. If you have any ideas or suggestions, I will appreciate it.
Re: Backfire?
« Reply #1 on: February 07, 2009, 11:56:21 AM »
first check would be the contact breaker points gap and then the ignition timing.
If the problem is still there then check the fuel side.
Re: Backfire?
« Reply #2 on: February 07, 2009, 12:02:50 PM »
I found that after i set up the tappets, the backfiring stopped alltogether, it used to do this on downhill runs in lets say 3rd gear, now no backfiring whatsoever, i know this is not the same problem as on your 126, but its just an idea  [-/
Re: Backfire?
« Reply #3 on: February 08, 2009, 06:57:58 PM »
Check your exhaust for leaks.
My bike backfires alot when the exhaust was leaking.
Re: Backfire?
« Reply #4 on: February 08, 2009, 11:30:57 PM »
 Have got a brand new exhaust on it, so it should be fine. Took it for test run today(done about 60 mls trip) and it seems to be better. It only does it at low revs, or when you switch the engine off! I`m assuming it must be the fuel.
 Well it was a joy to drive anyway :)
Re: Backfire?
« Reply #5 on: February 09, 2009, 09:07:21 AM »
sounds like unburnt fuel is exiting the exhaust valve and igniting in the exhaust manifolds downpipes , either your timing is out ie firing a tad to late as the exhaust valves are slightly open or you are running too rich a mixture .
Re: Backfire?
« Reply #6 on: February 09, 2009, 10:56:59 AM »
 Thanks for all the advice guys. I have tried the mixture screw already. Think I will try to tinker with the carb first and if this doesn`t help, I will try the timing...
Re: Backfire?
« Reply #7 on: February 09, 2009, 11:32:08 AM »
It's worth checking the insulation plate which is fitted under the carburetor. They can crack also check that the carburetor retaining screws haven't come loose this causes similar problems like you are experiencing.
fightingtorque
Re: Backfire?
« Reply #8 on: March 14, 2009, 09:06:42 PM »
If it's firing when you turn it off (running on) this is often caused by ignition timing being too late. causes the plugs to glow red hot.
I think there is a tendency for these cars to backfire occasionally on overrun because the ignition has a wasted spark - also fires on the exhuast stroke.  I get the occasional backfire from mine like this.
Re: Backfire?
« Reply #9 on: March 16, 2009, 10:49:11 AM »
I had a similar problem on my 500, where when it was revved really hard, a series of loud bangs/pops were heard coming out of the exhaust, often accompanied by a large blueish flame. The running of the car was never affected, but it did stop when I re-set my timing. I believe it was running too far advanced.
Sometimes I wish it still did it though as it sounded like a group B rally car!
