Author Topic: brake master cylinder problem? opinions?  (Read 3419 times)
phreak97
  • Niki!
« on: February 05, 2009, 12:42:33 AM »
Hi all,
my brakes have never been excellent and i was told about it when i bought the car about two years ago:P
recently though it's been getting worse, basically when i put my foot on the brake, it could firm up at any point it feels like, sometimes it gets pretty close to the floor before it goes hard, other times it's right at the beginning of the pedal travel as it should be, most of the time it's about half way. if it would just stay at about half way like it used to i wouldnt be worried, but a couple of times i've had to have a second go at pressing it to get the pressure up.
is this a master cylinder problem? can i get a seal kit or something for it? or am i going to have to try to find another cylinder?
regards,
james
phreak97
Re: brake master cylinder problem? opinions?
« Reply #1 on: February 05, 2009, 09:36:39 AM »
I had my master cyl replaced when i bought the car. Pretty cheap, easy to get here. Easy to replace too. Have you tried checking all the other parts? (shoes, wheel cylinders, drums, brake fluid, leakages and so on.) could be any of those things, and if there's one thing ive learned, its that no two 126 brake problems are the same  :P
phreak97
  • Niki!
« Reply #2 on: February 12, 2009, 09:42:36 AM »
i havnt tested those things, but i had to fix the brakes and bleed the system when i got the car, and the brakes have always sucked. i get in my friend's niki and just about go through the windscreen. they've never been dangerous though, i got used to how hard i have to press the pedal pretty easily.
I found a master cylinder in one of my many boxes of parts, how can i tell if it's good or not?
phreak97
« Reply #3 on: February 12, 2009, 03:42:15 PM »
Hi James,
Does the pedal go to the floor more often when you are turning the wheels, especially in full lock? I have found that mine often become very spongy for a few presses after I have had the car in full lock, I.E when parking etc.
For me the problem seems to be the flexi hoses compressing on one side when the wheels are locked.
« Reply #4 on: February 15, 2009, 02:05:25 PM »
Hi James,
this was a problem with a disc convercion in my case.........i think this one is master cylinder tho.......just fit new. i know your in Aus but....there must be parts out there?.................by the way if you hear of any 850 bits im just a bit north from you.....keep me posted eh?
« Reply #5 on: February 16, 2009, 10:08:07 AM »
Hi James,
Hi Dave, it seems my case was the same as yours. This happened as soon as I fitted the disc conversion. Did you manage to fix it, or just left as is. For me it doesn't really seem to impact on safety as you cant really be going too fast to have the wheels in full steering lock. Just a little concerned as to whether the flexi pipe may burst, as it will inevitably weaken it as it is?
« Reply #6 on: March 07, 2009, 03:59:34 PM »
hi dom, sorry to hijack the original post........no i never fixed it, i didnt see it as a safety issue..............
