Author Topic: Front Brakes  (Read 1843 times)
Eklipze3k
Front Brakes
« on: February 02, 2009, 01:11:48 PM »
Gotta change the cylinders and shoes on the front brakes, I'm going to blame it on the fact that I had a few drinks and stayed up late last night watching the Superbowl but how the hell do I take them apart??
Bear in mind I've never done this before, and do have a Haynes manual but without pictures I was lost  :oops:
Re: Front Brakes
« Reply #1 on: February 02, 2009, 01:56:33 PM »
take wheel off , undo 10mm bolt undo aligning bolt , pull off brake drum , look inside release springs take off brake shoes. open bonnet undo top on brake fluid resevoir . to undo cylinders you must first disconnect brake pipe behind cylinder and drain fluid off . beware as they can be very stubborn and you should use the proper spanner to undo them (its got a small openning just to let the pipe through and hugs all the nut). i would suggest just making sure they work ok and if they do and are not leaking to leave them alone i would more likely be inclined to simply replace the brake shoes and maybe brake drums if they are worn beyond their limits.
Eklipze3k
Re: Front Brakes
« Reply #2 on: February 02, 2009, 02:23:43 PM »
Thanks Mick.
It failed it's MoT on a brake imbalance, which was put down to the cylinders leaking but not having been able to get into it yet I've not been able to check the extent of this damage. If only it wasn't so damned cold I'd probably have had this done by now :(
Re: Front Brakes
« Reply #3 on: February 02, 2009, 03:08:03 PM »
as per micks instructions, + once the drum is off you'll see if the cylinders are leaking or even 'weaping' the brake dust will be caked up around the rubber end boots, by the way if fluid is evident,use just boiled water to clean it out.......
as mick stated, if the cylinders need replacing make sure you have the proper pipe fitting wrench........you might wana stick some new flexis on while your at it.
good luck
usefull tip for 126 mot, reverse the car and hit the brakes hard a few times,hard enough to lock up the front wheels,, thats how they adjust, sometimes this will re seat and equalise the brakes,also will bring the pedal and handbrake up. drums off and hot water wash helps your mot chances too
« Last Edit: February 02, 2009, 03:09:37 PM by 126dave »
Re: Front Brakes
« Reply #4 on: February 02, 2009, 03:47:56 PM »
my right front drum was leaking when i bought the car. You could tell by the fact that half of the drum fluid container was empty, and by taking the wheel off - the whole drum was sticky from the damn fluid. If this is the case, be sure to clean the fluid off the drums...
Re: Front Brakes
« Reply #5 on: February 02, 2009, 04:22:35 PM »
Ditto what the other guys have said & if you are thinking long term then it is worth investing in a brake pipe union spanner with a 10 mm end , like a small ring but with a cut out to slip over the brake pipe. If there is any major corrosion down there then open ended spanners can be bad news , a 10mm socket will be best to remove cylinders if you have to. Also worth spending a few pence on M6 x 12 stainless hex head screws when remounting cylinders. New brake cylinders come up cheap as chips quite often on the "Bay" but if your car has been standing for a short while it could be that the outer bore of the cylinder has picked up a little corrosion which could be cleaned up in situ. Not Rolls Royce engineering but with the application of the "right" type of grease can get you on the road as long as the main seals are not too scored. As brake fluid is water soluble then as 126dave says you can clean & restore with a good dose of boiling water in the right area. Also get a small ring spanner for the bleed nipple if you have not got one already. Also as it is described as a brake inbalence did the guy not tell you which side was down or was he one of those " I have the power therefore I will fail your car & leave you in the dark" type of guys.
