Author Topic: Battery light :(  (Read 2832 times)
nathan126
Battery light :(
« on: January 28, 2009, 10:20:47 PM »
I'm not sure if it's related to my new bulbs, and it's probably not..
but i can't seem to get rid of my battery light on the dash!  :(
my alternator is only a few months old, although it was a re-furb
can't for the life of me think what it is, has anyone else had this?
this is all a pain in the a*se  :(
Eklipze3k
Re: Battery light :(
« Reply #1 on: January 28, 2009, 10:23:06 PM »
Actually yes, and the battery that was in the car when I bought it was dead (ie. wouldn't hold a charge and barely gave enough volts to crank the starter) so I changed it and it went away  ???
« Reply #2 on: January 28, 2009, 10:24:22 PM »
is the battery charging up normally? this happened to me when i forgot to screw the wires back to the alternator after re fitting the engine. Probably means your circuit is cut short somewhere...  ???
« Reply #3 on: January 28, 2009, 10:45:19 PM »
There are 2 wires connected onto the alternator check the thin wire black/purple is connected (the one with the spade terminal)
nathan126
« Reply #4 on: January 28, 2009, 10:49:01 PM »
Yeah the battery's fine, and i haven't changed anything that could break the circuit. Both battery and alternator are recently new  :-
Had a look at the alternator about half an hour ago, although didn't measure the output.. I'll do that tomorrow sometime! tightened the belt and made sure my battery was connected (because i had it on charge the other day). It could be a bad re-furb i guess, went out there with my dad and he noticed the alternator was hot! He's an electrical engineer but not in cars, so we could go forever checking it all without having an idea what it could be. I'd only driven 2 miles, if it's not that then it's a puzzle. Stupid question, but without checking.. is there a main fuse for the alternator?
edit: Pete, the black/purple wires are connected.. although possibly dirty with slight play to the crimp. I'll check that tomorrow as well
nrg19uk
« Reply #5 on: January 29, 2009, 03:48:41 PM »
it shouldnt be hot!!!!! check the connections again make sure you have it wired correctly.
Neil gargaro
« Reply #6 on: January 29, 2009, 04:01:45 PM »
as far as i know the connections are idiot-proof, one has a connector, and the other one screws on... nathan, has this light been on all the time you had it? cos it might be a bad rebuild?
nathan126
« Reply #7 on: January 29, 2009, 10:01:02 PM »
It just came up yesterday morning.. either way it seems like its either a bad re-furb or the diodes have already gone! Taking the alternator into a company in newport tomorrow for them to re-refurb it, hopefully that should do it!
markie
« Reply #8 on: January 29, 2009, 11:25:21 PM »
I've had this problem in the past but took it into DBT motors and they sorted it in 2 mins,  They took the bulb out! (DBT Motors? Dell Boy Trotter)! LOL  :P Seriously though When I fitted the dvd player in mine I bypassed the Hand Brake display feed that seemed to cause a drain.  Have you fitted anything else new? Sorry don't mean to annoy by using the rather obvious Joke but it's late  ;D
« Reply #9 on: January 29, 2009, 11:43:15 PM »
my dvd player wouldnt work unless i plumbed it into my handbrake light, so i couldnt watch it whilst driving... ? tite or what...
so i put it onto the cig ligher instead.. lol
now i can watch tv, and drive... just kidding but my passengers do
nathan126
« Reply #10 on: February 02, 2009, 08:16:40 PM »
Sorted! cheers guys  :D
£32 to order and fit new diodes to the supposed "re-furbished" alternator!
turns out they normally just clean the diodes and sell them on again, false economy on my behalf
ah well, on the road again  8)
phreak97
  • Niki!
« Reply #11 on: February 05, 2009, 12:34:48 AM »
the battery bulb is in series with the line that powers up the alternator, if you take it out your alternator wont switch on.. have you had problems with dead batteries by any chance? :P
I dunno if im missing something, but i cant figure out your joke, so maybe taking that seriously was dumb, but oh well:P
phreak97
