Author Topic: Headlights ...  (Read 3469 times)
Eklipze3k
Headlights ...
« on: January 28, 2009, 06:00:13 PM »
Right, just took it for an MoT and one of the advisories was the n/s sidelight doesn't work. As I understand it there is only one bulb in each headlamp unit with 3 settings (dim/dip/full)?
If that's the case, and the bulb works fine on dip and full is there perhaps a fuse or relay I need to check somewhere?
Otherwise if it is a separate bulb (because I'll admit I haven't looked yet) what type is it?
Cheers y'all!
Re: Headlights ...
« Reply #1 on: January 28, 2009, 07:10:35 PM »
the headlight unit has two bulbs, one is the main bulb with a hi/lo beam, and the other one is the parking/position bulb, its the wery small, wery weak kind  :D, which by the way is useless in my case cos its illegal to drive with only the position lights on...  ::)
Eklipze3k
Re: Headlights ...
« Reply #2 on: January 28, 2009, 07:14:57 PM »
Yeah, I honestly don't see the point in them but it seems that - to pass an MoT - if it's there it has to work :(
Do any of the UK based folk know if these are stocked in Halfords?
Re: Headlights ...
« Reply #3 on: January 28, 2009, 07:31:37 PM »
your joking are you telling me the tester didnt replace it and charge you the cost of a bulb what a twat ,yes halfords will do them.
Eklipze3k
Re: Headlights ...
« Reply #4 on: January 28, 2009, 07:44:03 PM »
That would be an affirmative ... though I'd expect no less from Mr Clark  :oops:
What are they, 5/21w's ?
defender90
Re: Headlights ...
« Reply #5 on: January 30, 2009, 09:34:36 PM »
  These are 5 watt side light bulbs and it's a little known fact that it is LEGAL to drive in the UK with just side lights on at night time as long as the road has street lamps and has a speed limit not exceeding 30MPH.
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
Re: Headlights ...
« Reply #6 on: January 30, 2009, 09:51:30 PM »
The bulb number is 233 4w 12v bayonet cap  [-/
Eklipze3k
Re: Headlights ...
« Reply #7 on: January 30, 2009, 09:54:20 PM »
Spot on cheers Pete, I'll pick them up on my day off on Monday :D
phreak97
  • Niki!
Re: Headlights ...
« Reply #8 on: February 05, 2009, 12:50:20 AM »
umm.. mine are wedge bulbs im pretty sure cos i got my replacements from an arcade machine:P.. just pull one out and take it with you to be sure, you just take the black cover off the back and it's the little plug off centre in the glass, pulls out or twists or something i forget.. im gonna have a look myself in a sec.
the only times i've ever driven with my parkers (as theyre called in au) on is when i've had alternator or generator problems and i didnt think i'd get home if i used my headlights. i have no idea if it's legal or not, but i think theyre generally a waste of time. being called parking lights kinda makes me think theyre just for if you stop somewhere and dont want anyone to crash into you but dont want to use your headlights.. maybe if you have the engine off? not that useful anyway..
edit:
they are bayonette bulbs, my mistake:P
« Last Edit: February 05, 2009, 04:52:26 AM by phreak97 »
phreak97
goombas
  • 126p 1992 650e
    • www.wirtualnygostyn.pl/racing
Re: Headlights ...
« Reply #9 on: February 06, 2009, 07:56:02 PM »
we call them stand light, law calls the position lights
it is also elegal to drive with them in traffic in poland
if you think their to weak to drive try to fit LED's i'm not sure if they make a led type compatible for 126 but there is no problem to fit W5W or rgular LED diodes in 126 wires... they take low power give very good ligth make sure you buy a white one because coloured are elegal at least in poland
...if good thought that frontwheeldrive is better we would ended up walking on hands...
Re: Headlights ...
« Reply #10 on: February 06, 2009, 08:06:34 PM »
Well we can drive with position lights!! Well at least during the summer, and in daylight, but even thats good, cos the lights put a strain on my engine, idling with position lights is so much "easier"...
Eklipze3k
Re: Headlights ...
« Reply #11 on: March 04, 2009, 07:33:20 PM »
Ok, good ol' Italian electrics at work again. I've replaced the bulb and it still didn't work, so I popped the bonnet went back around the front and it was working  ??? Must be a loose connection somewhere, I'll have a look before taking it for the 2nd test. Brakes are done now, just gotta top up with fluid and test 'em ... hopefully I've done them right  ;D
Re: Headlights ...
« Reply #12 on: March 04, 2009, 09:36:57 PM »
Try using some sand paper and WD40 on those slots where you plug in the bulbs, they thend to rust and loose contact...
