Author Topic: Stripped wheel stud threads  (Read 3217 times)
custardboy
« on: January 24, 2009, 09:13:20 PM »
I have been busy putting my 126 back together.  Sorted the cylinder head, got the engine running sweetly and even quite pleased with my brakes after much fettling.
Got a set of alloys from a Cinquecento complete with nearly new Pirrelli tyres to replace the odd remoulds I had fitted.  The existing bolts where too short, so bought a set of new bolts and my mate fitted them for me whilst I balanced the carbs on his Triumph Stag.
However, later whilst admiring the new look of the 126 he told me the bolts had seemed very tight.  I took them off again to find the bolts where tight right to end of their travel and OMG all the threads have been stripped!!!!!! >:(
Specs said the bolts should be M12x1.25 on the 126 but appears the original short bolts where M12x1.5?
Now I don't know what to do?
I guess replacement hubs and stub axles are the only solution, bugger!
Anyone have any ideas?
Anyone have any hubs to sell?
Re: Stripped wheel stud threads
« Reply #1 on: January 24, 2009, 09:42:39 PM »
Oh Bugger :( I did the same when i bought a set of locking wheel nuts the first one i tried only went in 2 turns then i compared it with the original bolts and found out there 1.5 pitch.
I would look for another set of hubs, you don't want the wheels dropping off at 80mph.
« Reply #2 on: January 25, 2009, 06:21:25 AM »
you need 4 hubs.......and a night's worth of beer fom your mate.
« Last Edit: January 25, 2009, 07:10:09 AM by 126dave »
subvert73
« Reply #3 on: January 25, 2009, 09:32:27 AM »
No wonder your mate wanted you to balance the carbs on his stag, I'd hate to think how it would have run if he'd tried to do it!
Steve.
custardboy
« Reply #4 on: January 25, 2009, 10:12:19 AM »
He bought his Stag off ebay for 1500 quid so it was obvious it would be a wreck.  I have spent last six months rebuilding the engine and gearbox for him and he has been learning about cars along the way.  Though it seems he still has some way to go ::)
Yesterday I could have killed him, today I just feel resigned to neing without my baby a little more.
I had so looked forward to a day of sunday driving even in the rain.
Cheers for the advice guys.
nrg19uk
« Reply #5 on: January 25, 2009, 10:47:05 AM »
just a idea why dont you recut the thread to m12x1.25 and get some nuts to suit, or have they been completely stripped?
neil
Neil gargaro
« Reply #6 on: January 25, 2009, 11:45:01 AM »
 :yikes: :yikes: :yikes: That is a real horror story and I feel for you. Whilst those hubs are ultimately knackered and probably your new wheel bolts as well. The difference in the pitch on the thread is quite small and I would guess that if your mate tightened those bolt right up then both your hubs & the bolts now have some sort of compromise thread . You will have to source new parts but in the meantime if those bolts actualy tighten up you cannot do any more damage. So if the thread is not actualy stripped & the bolts tighten then you could probably use the car as long as you keep an eye on the bolts. Chasing out the hubs with a tap or chasing down the bolts will only remove more metal & make the bits that are gripping more likely to strip . Not great engineering but it might buy you a bit of time.
« Reply #7 on: January 25, 2009, 03:32:44 PM »
wouldnt it be easier to helicoil them?
« Reply #8 on: January 25, 2009, 04:56:09 PM »
would you seriously trust a helicoil on a hub thread? i bloody well woulnt .
banjomandolin
« Reply #9 on: January 26, 2009, 12:35:37 AM »
I have a pair of rear hubs complete with bearings, axles and flexible joints, i.e. the comlete assemblies except for braking compnents. They are sitting in my shed ready for you to collect from Quorn near Loughborough. They were on a 126 bis that had done 700 miles since it's last mot. Yours for peanuts. I don't have any front ones. I sold them last Sunday.
Banjo
« Last Edit: January 26, 2009, 12:40:56 AM by banjomandolin »
John Clark
custardboy
« Reply #10 on: January 26, 2009, 03:37:22 PM »
Well thanks to banjomandolin I haved sorted replacement rear hubs and am waiting to hear about some front ones, so hopefully soon I will be sorted.  The frustration is I have been using my 126 to commute to work for which it is perfect and feel lost without it!
« Reply #11 on: January 26, 2009, 03:49:14 PM »
i agree with mick, if they have been 'wound in' and are tightened up, id use the car as is while you get the new hubs sorted out......
as for helicoils,good suggestion but i wouldnt be happy with them in hubs, also by the time youve helicoiled all the stud holes your more than halfway way thro a swop, the fronts are a doddle, the rears a bit more interesting, still it gives you a chance to grease your splines eh?
custardboy
« Reply #12 on: January 26, 2009, 04:48:14 PM »
Bolts are all undone and wheels off as not possible to hold them on bolts just push in no retention, the front wheel fell off pushing it further into garage.
I have had a leak from the driveshaft gator so will fix this and grease the splines when I strip it down at the back so it will serve a purpose and be worth it in the end.
Just hoping doesn't cost too much to fix as eating into my electronic ignition fund.
Thanks for all the advice and to John for his help.
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« Reply #13 on: December 24, 2009, 10:33:16 AM »
hey custerdboy , what was the total length of the wheels bolts you needed for your cinq alloys on your bis please .
im in nottingham eastwood too .
merry christmas
richard
