Author Topic: Fuel Gauge Query  (Read 6092 times)
Eklipze3k
Fuel Gauge Query
« on: January 23, 2009, 02:14:01 PM »
Y'all should know I'm a complete noob by now ... does the fuel gauge needle move up with just the ignition on, or does the engine need to be running?
The reason I ask is I tried to start her this morning before going to work (just to let her tick over for a wee while and hear that lovely 2-stroke ;)) and it wouldn't have any of it, but the needle was sitting over empty. I was sure there was a little bit left in there but I could have been mistaken ...
Re: Fuel Gauge Query
« Reply #1 on: January 23, 2009, 03:38:11 PM »
it should come on with the electrics, if you were low on fuel you would be getting a warning light on aircooled little amberish light comes on .
« Reply #2 on: January 23, 2009, 03:45:23 PM »
you have a 2 stroke 126?.......wow....is it the steyer?..... :D sounds like your fuel is low....do you use premix or has it a seperate tank?....do you use castrol r?........ :D
« Reply #3 on: January 23, 2009, 03:56:03 PM »
now now dave.. ;D
Eklipze3k
« Reply #4 on: January 23, 2009, 04:03:32 PM »
Didn't see an amber light, only the battery light was lit. I'll get a wee jerry can anyway and pop some petrol in, just in case.
And I meant 2-cyl ... it's been a long day :P
« Reply #5 on: January 23, 2009, 04:54:35 PM »
 :) Hi Ekli , as no one has told you so far , to prevent any outbreaks of "foot in mouth" and perhaps prevent a mishap when you fill up with fuel your engine is a 2 cylinder 4 stroke. Also I must agree that the engine makes such a sweet noise on tick over.  [-/
Eklipze3k
« Reply #6 on: January 23, 2009, 04:57:45 PM »
Cheers Uncle ;)
Just to clarify then - the gauge itself should show the fuel level with the electrics on and engine off?
« Reply #7 on: January 23, 2009, 05:05:44 PM »
normally yes but i could be wrong start up and see then you have your answer!! i aint going outside to look because i its cold....
« Reply #8 on: January 23, 2009, 05:16:56 PM »
The bis gauge moves with just electrics, not sure about early aircooled, but should be the same...
Eklipze3k
« Reply #9 on: January 23, 2009, 05:18:36 PM »
Will check it when I get home, still stuck at work for another 3 hours yet  :oops:
« Reply #10 on: January 23, 2009, 05:42:00 PM »
well you should think yourself lucky that you have a job!! lol.
Eklipze3k
« Reply #11 on: January 23, 2009, 05:45:25 PM »
If you fancy a move, we always have positions available ;)
Ofc, it does mean talking to numpties about telephone bills all day  :-
« Reply #12 on: January 23, 2009, 06:07:54 PM »
at the moment thats sounds very appealling!!
« Reply #13 on: January 23, 2009, 06:19:08 PM »
cant beleive that you guys have job-finding problems too, i thought that the European Union has solved theese problems :D
« Reply #14 on: January 23, 2009, 06:23:36 PM »
the problem i am having is finding one that pays over 35k lol!!
