Author Topic: Replacing drive shaft boots.  (Read 2432 times)
« on: January 22, 2009, 02:00:03 PM »
 Hi everyone. Decided to replace both the inner and outer drive shaft boots on my 126, as there was a slight oil leek.
 Did what I thought I supposed to do and unbolted the shaft both ends, but still can`t get it out.
 Has anyone done this before? Any suggestions and ideas welcome.
 Thought it will be an easy job...well...live and learn.
Re: Replacing drive shaft boots.
« Reply #1 on: January 22, 2009, 05:59:03 PM »
righto on the driveshaft couplings at the hub end you have four bolts going into the silent block undo those , this will release the cast hub end on the driveshaft. there is a spring inserted in the middle of the hub nut and drive shaft end carefully remove this. then remove the c clip at the end of the drive shaft rim/end.you can now withdraw the cast end off of the drive shaft . clean up the drive shafts with a wirebrush/paper etc and then undo driveshaft gaiter /seal at the gearbox/dif end simply remove by sliding down the shaft. hope it helps
« Reply #2 on: January 22, 2009, 06:34:01 PM »
Well put Mick, This might help as well :D
« Reply #3 on: January 22, 2009, 08:40:39 PM »
 Thanks for all the info guys! Getting there slowly, but surely...
 The hardest bit is actually removing the drive shaft from it`s position as it`s so tight.
« Reply #4 on: January 22, 2009, 08:58:51 PM »
If you are saying what I think you are then it is because you cant get the outer flange on the drive casting down past the suspension arm but believe me it does go but you can slide the casting way back up drive shaft to give you a lot more room to play with when it is out of the way.
« Reply #5 on: January 22, 2009, 09:31:25 PM »
Make sure the splines on the drive shaft are not rusted up in front of the sleeve, clean them with a wire brush and oil.
The sleeve should move all the way up the shaft to the end of the splines, if it won't move tap lightly with a toffee hammer until it begins to split, then you can put 2 screw drivers in (one either side) and lightly prise the sleeve back. you should be able to see the spring (red) and the clip (Green) remove the clip and slide the sleeve off.
Clean the the drive shaft as Mick explained and slide the inner boot off.
When you re-assemble make sure you grease the splines as they slide in and out of the sleeve.
