Author Topic: hub spacer/pcd change  (Read 2739 times)
« on: January 20, 2009, 05:25:43 AM »
does anyone here know of a supplier of 98pcd hubcentric wheel spacers? im looking for a 25mm spacer 98pcd with 100 pcd studs...i may get some made if all else fails  :D
Eklipze3k
Re: hub spacer/pcd change
« Reply #1 on: January 20, 2009, 08:49:21 AM »
Do you also need it to change the centre bore for say VW fitment? If so, check here - http://www.europerformance.co.uk/pages/products/manufacturers_subcategory.mhtml?category=wheels;manufacturer=hrwheels
They've got both types (hub adaptors and hubcentric spacers), just choose FIAT Cinq when it comes up with a list of cars
« Reply #3 on: January 20, 2009, 10:38:22 AM »
thank you gentlemen......... :P
« Reply #4 on: January 20, 2009, 02:23:44 PM »
I have 25mm Hubcentrics from Eibach pro. Think they are pretty expensive, but I picked mine up (used) for around a tenner on ebay last summer. Not sure about ones with studds fitted though. Without hubcentric, fitting the wheel is a nightmare, not to mention the safety issue of running without.
« Last Edit: January 20, 2009, 02:27:03 PM by Dom »
