Author Topic: Carb... trouble ...... i think.....  (Read 2111 times)
toby-toby-two
« on: January 19, 2009, 10:10:37 PM »
Help Needed! I live in Washington, Tyne and Wear and i recently took my fiat 126 (1991) to a garage as it was poorly. Anyway to cut a long story short they told me i needed a new ch0ke cable and carb as the choke cable had snapped inside of the carb. They charged me £75 to tell me that. So what i am looking for is some advice on 1) where can i find a carb i have bought the choke cable off ebay, and 2) does anyone know of a garage in the north east of england pref washington, sunderland or newcastle that knows a little about these cars and hopefully make me a very happy lady by fixing my little man....... Sandra
Re: Carb... trouble ...... i think.....
« Reply #1 on: January 19, 2009, 10:41:29 PM »
right the choke cable doesnt go into the carb its connected outside of the carb, it might be that the plastic arm that is inside the carb (on the polish type carb) has broken which is common , but then again the car will be operable even without the choke ,you can get the carb refurbished but doubt that they can remedy the broken arm for the choke . first check the car to see if you have a weber carbureteur or the polish type if its a weber then search for a weber dealer they will be able to direct you to a local garage who will refurb your carb if its the later polish carb then give it a clean out and try running it while looking for a replacement , new carbs tend to be pricey nowdays maybe a bis owner can give you more clues as to where you can get one.
banjomandolin
« Reply #2 on: January 21, 2009, 11:36:37 AM »
This sort of situation makes me want to weep, a lady in distress ripped off by a money hungry garage. Where are the north east Bis owning Knights In Shining Armour ?.
banjo
John Clark
« Reply #3 on: January 21, 2009, 12:01:40 PM »
im here, well im northwest knight in shining amour, if you want my webber carb id sell it to you... i have no idea about price tho.. some1 help
whats it worth?
« Reply #4 on: January 21, 2009, 03:25:52 PM »
Knight in pink armour... lol
« Reply #5 on: January 21, 2009, 04:11:30 PM »
how does, fifty quid sound?  8)
banjomandolin
« Reply #6 on: January 21, 2009, 07:56:07 PM »
Steady on !  don't forget a modern garage diagnosed the problem as carb. They only know about injection. Step forward Knight In Shining Armour with an open mind
banjo.
John Clark
« Reply #7 on: January 22, 2009, 09:18:08 AM »
25 spots is more like it.
