Author Topic: umm.. choke probs with a triumph herald:P  (Read 2005 times)
phreak97
  • Niki!
« on: January 17, 2009, 07:46:09 AM »
ok, so it isnt a 126.. but it is european, so hopefully someone on here will be able to help anyway..
basically the little arm that sits on the choke cam to move the butterfly valve is missing.. anyone got a replacement or know where i might find one? otherwise does anyone know of some other cars that have the same carb?
even a photo of what i'm looking for would help..
phreak97
Re: umm.. choke probs with a triumph herald:P
« Reply #1 on: January 17, 2009, 09:22:07 AM »
 ??? What carb is it?
« Reply #2 on: January 17, 2009, 11:05:48 AM »
Interesting, the bis almost always looses the same piece cos its made of plastic, i basically don't have a choke cos of this...  :P
phreak97
  • Niki!
« Reply #3 on: January 17, 2009, 01:14:56 PM »
i dont know what carb it is.. it's the default herald carb.. it's a friend's car, i dont know much about triumphs specifically.
i should have taken a photo.. didnt even think about it.
phreak97
« Reply #4 on: January 17, 2009, 01:37:07 PM »
find out the model, the herald came in three different size engines a 948cc, 1200 and a 1360. I think they all had different carbs?
I might be able to locate one in the UK with the correct model info. :-
phreak97
  • Niki!
« Reply #5 on: January 23, 2009, 01:28:57 PM »
it's a 1200 with a solex carb, dont know the model number of the carb though..
the bit is just flat oval shape with a hole for the axle that goes through the butterfly valve, and a shaft poking off the other end that rests on a cam, held there by gravity alone it seems.
phreak97
