Author Topic: broke wheel bolt ARGGHHHH ..anything i can do ?  (Read 3618 times)
richard
« on: October 02, 2005, 05:14:13 PM »
hello there i recently, well the other day infact got a punchure , and so removed the punchured wheel and replaced it with my spare ..
and tightned bolts gingerly but i thought they were fine .
but i then got a flash back of when i had my mini and had a flat and replaced tyre . and after 100 or so meteres the wheel shock off and i damaged the brakes/hub
so i went back to my fiat 500 and tightned them a little more ... ARGGHHHHHHHHHHHHHHHH  LOW AND BEHONE ONE HAS SNAPPED OFF :(    ..HALF INSIDE THE DRUM/HUB AND HALF IN MY HAND ?????
IS THERE ANYTHING I CAN DO PLEASE TO REMOVE IT ?  .....  AND I REMEMBER SOMEBODY TELLING ME ONLY THE OTHER DAY TO GET A SET OF FIAT PANDA WHEEL BOLTS ARE THE 500'S WERE DODGY ?  . IS THIS INFO CORRECT AND IF SO CAN ANYONE POINT ME IN DIRECTION OF A FULL SET PLEASE?
ANYHELP WOULD BE FANTASTIC ......
all the best
richard
« Reply #1 on: October 02, 2005, 05:21:52 PM »
You may be lucky and have enough stud protruding to grip it with a mole grips. It should no be to tight because the wheel is off.
Failing that, you could take the drum off and grip the stud in a vice
Failing that, place a nut over the broken stud and weld it to the stud, the heat also then helps to loosen it.
good luck
richard
3 bolts ?
« Reply #2 on: October 05, 2005, 07:51:43 PM »
hello there , thank you for your help with my broken fiat 500 snapped wheel bolt, i had to take the hub off and take it to work and get the mechanic to drill it out for me, its fantastic now
i do however now require another wheel bolt , anyone got one i could have please ?
if not can you suggest a replacement bolt ? a man told me fiat panda bolts fit ???  but didnt say what year ? anyone know if its true, or they have an alternative ?
ive got a torque wrench now only ?1 from the car boot ( bargain hey :)  ..hehe)
please get in touch and anyhelp would be fantastic
Darkhorse
« Reply #3 on: October 06, 2005, 09:45:40 AM »
I have plenty of hubs,wheels and bolts so give me a shout on 07707 389240
Bruce
« Reply #4 on: March 23, 2006, 12:19:44 AM »
go to a tool shop and buy a set of stud extractors, it is a tool with a reversed taper thread on one end and a square shoulder on the other; drill a whole down the middle of the stud, screw in the extractor (turning it anti-clockwise screws it in), once it bites it will draw the broken stud out.
