Author Topic: Brakes  (Read 4113 times)
custardboy
Brakes
« on: January 12, 2009, 06:04:52 PM »
I'm confused, I have never had very good brakes since I got my 126 late last year in fact they are down right dangerous.  It came with a fresh Mot and has had new brake shoes and cylinders all round.  I have bled in three times with no problems plenty of fresh fluid comes through with no air bubbles, I've even tapped the master cylinder for good measure.  I get a good solid pedal about an inch or so or travel, but I still have no brakes!
The handbrake works but the lever comes up quite high.
It feels as though even with all my considerable weight on brake pedal the shoes are only just catching the drums.
Is there some kind of adjuster on the shoes which needs slack taking up or might it be fault with the master cylinder?
Re: Brakes
« Reply #1 on: January 12, 2009, 09:49:43 PM »
126 brakes will never match up to the modern servo disc/drum or disc all round set-ups, That why 126 drivers are better drivers! cause we have to predict stopping half a mile ahead ;D
Here's how to adjust the handbrake so you don't hit your chin every time you put the handbrake on :D
Some 126 owners are opting to put front discs on to help stopping power at high speeds, driving round town at low speeds should not be a problem :)
custardboy
Re: Brakes
« Reply #2 on: January 13, 2009, 12:10:57 AM »
Cheers for the information Pete, that will help me adjust the handbrake.
I know that drum brakes are not as good as modern systems, I've had all round drum brakes on several cars, moggy minor, landrover, 2cv, and I have had an original 500.  But these just don't feel right, almost not there at all I went out tonight for a little spin nearly quite literally as it is braking unevenly, so am wondering whether one cylinder or adjuster isn't functioning properly.
When I bought the 126 the guy said on my short test drive to be careful of brakes as it had been sitting for a while and when I picked it up he again said go careful on the brakes as he thought the rain had got on the brakes.  He was the one who had fitted the new shoes and cylinders and I'm wondering whether he couldn't get them right, hmm!
Re: Brakes
« Reply #3 on: January 13, 2009, 12:33:14 AM »
It does sound like you have some kind of problem if the brakes are pulling uneven. The 126 brakes aren't very efficent like pete says but they should be no worse than a Fiat 500.
The mot test should spot any braking problems or inefficiency's, when was the car mot tested?
Sounds like you need to take the drums off, to check for faulty slave cylinders or glazed or oil contaminated linings.
custardboy
Re: Brakes
« Reply #4 on: January 13, 2009, 10:06:45 AM »
The Mot was September last year only three weeks before I bought it, whether it should have passed I don't know, but there you go, I've had cars with worse defects sail through and other times received a fail for a blown bulb.
I'm beginning to wonder if they are just not bed in, as all told it has probably done less than 100 miles since the Mot and having new linings and cylinders fitted.
Upon examination of the front brakes I have noticed that the near side trailing shoe has no brake shoe retaining pin fitted but it doesn't seem to move out of position, not sue I can see how this would affect braking performance though?
My dad has suggested putting a chamfer on the leading edge of the brake shoe lining to aid bedding in as we did on an old Landrover IIa, is this something anyone else has had to do?
Another thing that is confusing me is I have a good solid brake pedal with no more than inch of travel - but the drums spin freely with brakes released as if shoes are no where near the drums, the adjusters should bring the shoes close to the drums so you can just feel some resistance - yes?
Maybe its the pedal as it feels rock hard after an inch of travel like stepping on a brick, almost as if I can't go any further, come to think of it, it wouldn't go any further when I bled it, I used an easibleed though?
Re: Brakes
« Reply #5 on: January 13, 2009, 12:38:24 PM »
That brake pedal should go right to the floor with one of the bleed nipples open. I think you need to check out that master cylinder.
Re: Brakes
« Reply #6 on: January 13, 2009, 02:15:28 PM »
I thought someone said somewhere that the 126 has a dual brake master, one part does the front, the other the back? :oops:
Re: Brakes
« Reply #7 on: January 13, 2009, 05:06:35 PM »
Only thing that happened to me, with similar effect was that i bought brand new brake shoes, which were the correct size and all, but the adjusting spring was a bit longer, so it somehow impaired my braking, it turned out that the brake shoes were for a fiat 128 not 126, so make certain you have the correct shoes... hope this helps. G 8)
custardboy
Re: Brakes
« Reply #8 on: January 13, 2009, 10:10:36 PM »
Thanks for the advice, I am beginning to think it is something to do with the brake linings.  I have checked the pedal and does travel to floor when bleeding the brakes and there seems to be good pressure, also the adjusters seem set right.  Went out for drive tonight and there is feeling of brakes juddering which can be felt through pedal.
Re: Brakes
« Reply #9 on: January 13, 2009, 11:55:29 PM »
I have the same feeling, but the brakes work fine. o think its the drums gone oval feeling... could be wrong...
Re: Brakes
« Reply #10 on: January 23, 2009, 07:54:54 PM »
dont forget that 126 drums are self adjusting.....they adjust when you reverse.......so somtimes flying backwards and hitting the pedal hard a few times will bring the pedal up......just a thought from a long retired 126'er
Re: Brakes
« Reply #11 on: January 23, 2009, 09:01:21 PM »
Didnt know that... thanks retired 126dave  :D :D [-/
defender90
Re: Brakes
« Reply #12 on: January 30, 2009, 09:55:08 PM »
  Only adjust in reverse???????
They only adjust as they wear and the self adjusting mechanism has to travel past the pawl, forwards, backwards, sideways, upside down, not moving at all, any way you like as long as you pull the hand brake on!
Kevan
Radcliffe
Gt.Manchester
Citroen BX TDG (soon to go)
Citroen BX TZD
Land Rover 110 Station Wagon
