Author Topic: air cooled 126 taps/knocks  (Read 1600 times)
markie
« on: January 11, 2009, 02:43:32 PM »
Hello eveyone.
I've been a member for a while but have only just got round to looking at this new site and have a question!  My air cooled 126 taps/knocks on overun, I have replaced the conrod shells, have good oil pressure, adjusted the valves between 0.20 inlet  0.25 exhaust out to 0.25 inlet and 0.32 exhaust but this makes no differance.  head gaskit done as have all other gaskits, cleaned out the centifugal oil filter, disconnected the fan belt atc to no avail.  The really annoying thing is that I have 2 engines and they both do it! could this noise be caused by the gearbox?
All the best Peeps
Re: air cooled 126 taps/knocks
« Reply #1 on: January 11, 2009, 06:34:22 PM »
Welcome!
I have an air cooler too. It also makes taps etc when she gets warm, seems silent when it is cold.
The clearances were 0.10 and 0.15mm I think, might need clarification. I have simply kept three blades off of an old feller gauge in the toolkit.
One for the points, and the other two for the tappets  [-/
My feeling has been that perhaps it is the camchain. I have a new one and am going to fit it as soon as the weather looks up so will report my findings.
Same as you I have tried to isolate the noise by running it temporarily without the fan belt etc etc. I even went to the extent of taking the fuel pump off.
Pity they clatter as when they are quiet, and with my sporty exhaust it sounds like a ducati bike or harley :oops:
Have a look through the forums and you will see my discussion under engine noise.
markie
« Reply #2 on: January 12, 2009, 01:38:47 PM »
Cheers Chap,
I have read some of the posts but what gets me with mine is that I have a second engine and that does the same I think I may try running the engine out of the car just to see if it's the gear box.  but if you think of anything...
Cheers Markie
MaLi
« Reply #3 on: January 12, 2009, 02:01:56 PM »
Check if the valve rockers are not worn out. Look at the surface which is in contact with thevalve. If it is worn you will not be able to set the correct valve clearances.
 8)
