Author Topic: disc brake conversion questions  (Read 2257 times)
« on: January 06, 2009, 10:08:58 PM »
2 questions-
1- do you use the cinq or 126 wheel bearing (I want to fit new ones when I do the conversion and want to buy them ahead of time)
2- where can I get brake hoses from as my goodridge hoses arent long enough and I need some that will go 126 to cinq calipers
many thanks  :)
Re: disc brake conversion questions
« Reply #1 on: January 06, 2009, 11:04:30 PM »
You use the original 126 hub and bearing, as for the flexy i am going to use cinq ones then get new solid brake pipes L/R from the strut to the master cylinder with the correct ends on :)
