Author Topic: gearbox care!  (Read 5920 times)
joda
gearbox care!
« on: January 04, 2009, 09:56:19 PM »
few of us have had gearbox problems in the last week while,
 ive fitted my gearbox, and its great to be back in the 126, but find that first is sometimes a bit funny to find, crunch crash bang
whats the best way to get first gear everytime to preserve the life of the gearbox?
126Bis
Re: gearbox care!
« Reply #1 on: January 04, 2009, 09:59:27 PM »
Coming to a complete stop??  :P
Re: gearbox care!
« Reply #2 on: January 04, 2009, 10:33:50 PM »
also, why does my gear stick spin 360 degrees, its so anoying!! it stops me getting changes right!
any1 know how to fix it?
Re: gearbox care!
« Reply #3 on: January 05, 2009, 09:27:35 AM »
mine spins too, but i think its normal, but what has it got to do with gear changing, let me guess, you dont know where the gears are, so you have to look at the little diagram on the stick, but its upside-down so you use the wrong one??  :oops: xmas1 </4 </4
by the way, would some of our more seasoned members mind explaining the concept of "double de clutching" to us newbies, as they don't teach this in drivers school, and i would very much like to know :D
Re: gearbox care!
« Reply #4 on: January 05, 2009, 10:29:56 AM »
You don't need to double de-clutch on any 126 box. It was essential on the early 500 'crash' gearbox with no synchro. It has been argued that you need to double de-clutch on the 126 box when shifting down into 1st (as there is no synchro on 1st), but in reality, you shouldn't have to shift down into first when the vehicle is moving, thus eliminating the need.
Double de-clutching is essentially, putting your foot on the clutch, then sticking the gear stick in neutral, then back on the clutch, selecting the gear and finally releasing again. You would have to do this when changing from any gear, to any other gear on the old 'Crash' boxes. As well as this, you would have to carefully match the revs, to the right gear to avoid the dreaded crunching sound.
Re: gearbox care!
« Reply #5 on: January 05, 2009, 10:48:09 AM »
Thanx Dom, yes i was thinking about 1st gear, just curious i guess, once i get my bis rolling again ill try to use the 2nd gear like some members suggested...
Re: gearbox care!
« Reply #6 on: January 05, 2009, 10:53:02 AM »
as stated continuously on this site dont change down into first if your still moving!! use it as a pullaway gear only!
Re: gearbox care!
« Reply #7 on: January 05, 2009, 11:31:21 AM »
may i add also...if your in nuetral, clutch up at the lights....before you select 1st, select second, then 1st, so, clutch down,drop into 2nd then go into 1st, doing this uses the syncro 2nd gear to stop the gear cluster spinning at engine idle speed and helps to eliminate ANY crunch into first.
a good tip is every time you crunch 1st or reverse, stick a pound coin in a tin.......youll have enough for a new 1st/reverse gear by the time you ruined your good box.  ;D
phreak97
  • Niki!
Re: gearbox care!
« Reply #8 on: January 05, 2009, 03:01:25 PM »
im pretty sure you mean what i was going to write, but even i was confused by your explaination and i know what youre talking about, so i'm gonna explain it my way anyway.
basically yeah, you want to use the synchro for second to stop the gearbox spinning before you engage 1st.
once youre at a complete stop (and ready to get going again), push the clutch pedal in (if it isnt in already), move the shifter into second, then into first, now youre in first with no crunches! you can let the clutch out and take off as usual.
i got into the habit of doing this a good 8 months ago, i've learned that you dont actually have to engage second gear, you can feel the synchro stop the box just before you actually get there, as soon as you feel that little clunk you can jam it into first, you dont have to wait at all. it barely takes any extra time and itll save your first gear.
one note though, occasionally first stops with the teeth lined up so it cant go in, in which case you have to move back to neutral let the clutch pedal out, then start all over.. still takes no time at all once you've done it a few times. definately worth it.
the same thing can be done if reverse crunches (mine doesnt seem to?), as theres no synchro there either, i'd use third instead of second though, just cos it's closer. when youre not moving all the sychros should have the same effect.
i'm really glad this thread came up.. if everyone did this then worn first gears would be a thing of the past..
« Last Edit: January 05, 2009, 03:06:35 PM by phreak97 »
phreak97
Re: gearbox care!
« Reply #9 on: January 05, 2009, 03:35:35 PM »
now theres a pain in the rear part of your body...  ::) :P
Re: gearbox care!
« Reply #10 on: January 05, 2009, 05:41:57 PM »
 [-/ Excellent & one of the things I love about this site is the pearls of wisdom that get posted. That is the best advice I have heard recently on how to beat the crunch !!  ;) ;) Also looking at the Blitz web site there seems to be an arguement for reverting back to a non syncro Fiat 500 box for strength of gears and low close ratio gears if you want something nippy about town. Has anyone ever fitted a Bis diff on a 500 box?
Re: gearbox care!
« Reply #11 on: January 06, 2009, 01:04:46 PM »
[qu
[/quote]
im so sorry to have confused you, i'll shut up now and fade away like old 126'rs should. ta da.
Re: gearbox care!
« Reply #12 on: January 06, 2009, 04:14:10 PM »
ha ha  ;D
skelz
Re: gearbox care!
« Reply #13 on: October 26, 2010, 08:23:00 AM »
Sorry to drag this one up.. is there anything wrong with taking off in 2nd gear ?
Re: gearbox care!
« Reply #14 on: October 26, 2010, 08:42:12 AM »
it might put a bit of a strain on the gearbox/clutch and be a bit of a slow start but many folk have been forced down this road when the first gear has gone i would recommend that if first is available then use it but remember it is solely a pullaway gear and make sure you have stopped completely before selecting first again (for example at junctions) even if you double declutch and try to engage first it can still be a bit hit and miss and end up crunching the gears so best to avoid.
