Author Topic: headlamps  (Read 1995 times)
headlamps
« on: January 02, 2009, 05:44:01 PM »
Just a thought..
I have been messing about with my headlamps and have found new bulbs on e bay.
They were xenon 410 or somthing like that.
They go in ok and much whiter than standard ones although I think a relay would make the lights brighter as testing the voltage at the headlams I seem to only have 9.5Volts.
I noticed the bulb goes in lovcated by a slot, slightly twisted right (clockwise) when looking at the headlamp from behind.
Has anyone bought the new left hand drive headlamps? Is the slot located so as to turn the bulb slightly to the left (anticlockwise)?
subvert73
Re: headlamps
« Reply #1 on: January 02, 2009, 07:09:30 PM »
Hi Darrell,
I've just fitted a pair of new LHD headlamps (which I converted to RHD using some old lenses). The new LHD lamps have 3 slots and use an H4 bulb which have 3 different size tabs. Therefore the bulb can only go in the correct way, which is, from memory, with the dipped filament pointing upwards (small reflector inside the bulb underneath). This means that all the dipped beam light hits the top half of the headlamp reflector (back of the lamp) and gets reflected downwards, hence "dipped" beam. The beam is then directed left or right as is passes through the lens, depending on whether RHD or LHD lenses are fitted.
I hope that makes sense, it's quite difficult to explain.
As for Xenon bulbs, I've also just ordered a pair from ebay. It'll be interesting to see whether they make much difference?
After reading your post I'm going to check the voltage at my headlamps tomorrow, your suggestion of fitting a relay could be a good idea? [-/
« Last Edit: January 02, 2009, 09:18:50 PM by subvert73 »
Steve.
Re: headlamps
« Reply #2 on: January 02, 2009, 08:19:03 PM »
Are the Xenon bulbs you're talking about real xenons with ballasts and stuff or just h4 imitations?
oh, and did you test your voltage while idling, engine off or higher revs? ive found that my bulbs shine is proportional to the engines revolutions.
p.s. if you guys are talking about real xenon bulbs i would recommend installing relays cos xenons tend to burn out faster when the voltage isn't constant....
subvert73
Re: headlamps
« Reply #3 on: January 02, 2009, 08:54:40 PM »
Hi Gordan,
These are standard H4 bulbs filled with xenon gas instead of halogen gas.
The HID xenon conversion kits with ballast resistors that you mention are illegal to retro fit in the UK. They are fitted to new cars provided that they also have a headlamp cleaning system and automatic level adjustment.
This doesn't mean a car with retro fitted HID xenon kit will fail an MOT, (It may or may not), but if the police stop you they can issue you with a producer giving you a limited amount of time to remove the conversion.
Steve.
Re: headlamps
« Reply #4 on: January 02, 2009, 09:09:58 PM »
Thanks for that, thought it might be the lenses  ::)
My train of thought was that perhaps the positioning of the bulb in the lamp had something to do with it alas not.
I suspect the BIS has a headlamp relay, my memory is a bit vague as to the condition of the lights on my BIS being I last drove it 2 years ago and has been disassembled to the extent it wont run.
I wonder if anyone can say if the BIS has a relay and if the lights are good or not?
My car is air cooled it will put the voltage in the system up to 13.5Volts with no lights on.
Put the lights on the voltage drops.
The alarming thing was the low voltage at the bulbs which makes me wonder where I am loosing voltage! :oops:
Re: headlamps
« Reply #5 on: January 02, 2009, 09:39:03 PM »
As far as i know the standard european lhd BIS has no relay for the headlights, but if i remember it correctly, it was ciaoflyer, who discovered headlight relays on his rhd model, and mentioned something about it being a must for british regulations?
as i said before, im getting myself a hid xenon conversion kit soon, so ill let you guys know how it turns out... ;)
Re: headlamps
« Reply #6 on: January 05, 2009, 04:47:43 PM »
Yes in the UK at that time we had a Dim-Dip device fitted which is operated by two extra relays, see this link:
http://en.wikipedia.org/wiki/Daytime_running_lamp
Also if you look in the Bis users manual, there are two Headlamp wiring diagrams, one for the UK with Dim-Dip and one for overseas without Dim-Dip.
