Author Topic: Accelerator pedal problem - any ideas?  (Read 1551 times)
chrisrhodesinlbz
« on: December 28, 2008, 08:11:46 PM »
Hello Forum members, I hope that you can help.
I had a trip out to see my sister in Barnes today in my bis, about a 100 mile round trip. Anyway everything was fine on the way there, but on the way back on the very busy A4, I lost all throttle and managed to limp into a side street in Chiswick with the help of the choke.
Looking about in the pitch dark, it seemed that the engine was running fine, but the accelerator pedal wasn't doing anything, there is not much resistance, it seems that the cable is not attached to it anymore.
Anyway I ended up being trailored home at a cost of £207! My Direct Line breakdown cover only covers a 10 mile tow to  garage apparently.
Does anyone know of the most likely places to look for the problem. I'm back to work tomorrow so will have to do an investigation in the next bit of daylight I have, but any advice will be very greatfully recieved.
Re: Accelerator pedal problem - any ideas?
« Reply #1 on: December 28, 2008, 08:23:50 PM »
Hy Chris  ;)
try this, when you look at your carburettor there should be a cable with a plastic square thingy attached to it (its white, its the accelerator cable) see if thats still attached, if it is, try pulling it and see if the pedal moves. if it moves its something more serious but i doubt it...
hope ive been of any help. cheers. Gordan
p.s. just noticed... 900th POST!!!  :D :D
« Last Edit: December 28, 2008, 08:33:30 PM by Gordan »
« Reply #2 on: December 28, 2008, 10:31:25 PM »
if its attached at the carb end and you cannot rev via the pedal its either your cable has broken or the arm at the end of the accelerator pedal bar has come off/ loose. you need to remove the centre consol and the metal tunnel underneath beware as the nuts that hold it all together are usually rusted up so the bolts might just shear off . look at the arm and if its loose then reattach it and hammer it over at the end (this is how its attached in manufactuer!!)or better still give it a tack weld. if you ever have a broken accelerator cable you can always take off the engine lid and drop the back seats and fix up an alternative cable through the car just to get you home so its worth while to have some strong string or wire in your car just in case of emergencies..
