Author Topic: Rubber Brake Pipes  (Read 1583 times)
custardboy
Rubber Brake Pipes
« on: December 19, 2008, 02:37:37 PM »
My brakes have always been poor, very poor in fact, even with new brake cylinders, shoes, fluid, master cylinder, etc.  After some thorough investigation it seems the rubber brake hose/pipes between the brake reservoir and the master cylinder are perished and leaking but I have been unable to find replacements and it doesn't seem possible to buy rubber hose suitable for brake fluid by the metre.
I have been told that it is possible to use compressed air hose, type that is orange/red on outside and black inside, does this sound right?
Alternatively anyone have any ideas where I can get some suitable brake hose?
Thank you
Re: Rubber Brake Pipes
« Reply #1 on: December 19, 2008, 04:01:42 PM »
Those pipes are just a gravity feed into the master cylinder so assuming that the fluid has got through when you bled the brakes they should work OK but the reservoir would need to top up the system to compensate for wear and brake action. Getting suitable pipe should be no problem from a decent motor factor, don't mess with Mr Halfords because it will not come ready packed. If all that stuff is new then the brakes should be spot on. My brakes were poor so I went to ASDA & got brake fluid at £1.50 for 1/2 litre and gave those brakes a mother of a bleeding which seemed to flush out the deamons. Also if that brake fluid has been leaking out inside your bonnet area I would flush it out with plenty of water, I used it straight from the kettle. The brake fluid will strip your paint but is water soluable if you get it in time.
fiatmacedonia
Rubber Brake Pipes
« Reply #2 on: December 22, 2008, 09:18:50 AM »
rubber brake pipes, for fiat 126, is 20euro/pcs.
best regards
goran,macedonia
