Author Topic: power loss  (Read 5632 times)
kerry
power loss
« on: December 10, 2008, 08:44:58 PM »
when driving along, i've found our bis loses power after driving about 10-15 minutes. i push the gas pedal and nothing happens, it's almost like it's having the opposite effect. then when the pedal gets all the way down, suddenly i get a bit of acceleration.
when this happened the other day, i was slowing quickly to stop behind a bin lorry, so i dipped the clutch and it stalled...
after stopping for a few minutes, it was reluctant to restart but then there were no more problems for the rest of the 11-mile journey.
it's had a recent service which included all the basics like changing HT leads, setting the carb, new spark plugs, resetting the points.
anyone got any ideas?
Re: power loss
« Reply #1 on: December 10, 2008, 08:54:17 PM »
only thing i had similar problems with was the fuel pump, which used to stop working when it got hot... try checking it when its hot...  [-/
Re: power loss
« Reply #2 on: December 10, 2008, 09:15:39 PM »
it does sound a bit like your fuel pump is giving up , when you want more fuel it cant supply it quick enough so it just sort of dies on you . if you are set on keeping the car then get an electric fuel pump and say goodbye to anymore fuel agro, a pacet solid state low pressure pump will do the bizz. they are easy to fit so its a d i y job if you fancy it.
Re: power loss
« Reply #3 on: December 10, 2008, 09:19:46 PM »
Only other thing i can think of kerry is there could be some sediment in the carb, when you braked hard it could have been suck into the main jet so i'd take the top of the carb off and look for brown sediment in the bottom of the carb, Have you got an inline petrol filter on?
Re: power loss
« Reply #4 on: December 12, 2008, 09:28:19 AM »
The fuel pump is run by a rod that goes down into the engine and runs on a cam.
From my experience the rod wears.
As you played HT leads maybe the distributor moved a bit when attaching the new leads.
Where abouts in Somerset are you?
I am Hampshire and travel throughout Somerset for work.
kerry
Re: power loss
« Reply #5 on: December 12, 2008, 11:11:43 AM »
... get an electric fuel pump and say goodbye to anymore fuel agro, a pacet solid state low pressure pump will do the bizz. they are easy to fit so its a d i y job if you fancy it.
don't suppose you'd know where i can get one? or for how much roughly?
kerry
Re: power loss
« Reply #6 on: December 12, 2008, 11:12:30 AM »
I live in Bridgwater but drive the car to work in Taunton every weekday.
Re: power loss
« Reply #7 on: December 12, 2008, 04:14:43 PM »
I would also like an electric fuel pump.. post a link to one please  [-/
Re: power loss
« Reply #8 on: December 12, 2008, 11:30:29 PM »
any motor factors or any classic car or  motor sport spare suppliers will sell them, i bought mine at a kit car show for about 30 odd notes if i remember rightly , have a look on ebay for pacet fuel pumps .
kerry
Re: power loss
« Reply #9 on: December 13, 2008, 11:36:14 AM »
Thanks for your responses guys.
OK, I took the fuel pump off and that rod seems to be alright. Whet you say 'worn', what should I be looking for?
I've got a receipt from the previous owner which shows the fuel pump was changed at 27,031 miles on 26/11/2004. Mileage is now reading 31,441. Surely it should last longer than 4 years/4k miles?
The carb is clean inside and there's an inline fuel filter.
Any more ideas, anyone? Is an electric pump the way forward?
Re: power loss
« Reply #10 on: December 13, 2008, 11:46:04 AM »
The electric pumps are the way forward :D check the points are set properly and not burnt, also replace the condenser.
Re: power loss
« Reply #11 on: December 13, 2008, 12:46:25 PM »
the pump may have been changed but the pushrod may be worn , I cant remember how long it should be but Im sure someone on here should know might be worth pulling it out and measuring it....
Re: power loss
« Reply #12 on: December 13, 2008, 02:24:52 PM »
has the car sat around for long periods as moisture attacks the spring in the fuel pump and corrodes it so it doesnt operate correctly .
Re: power loss
« Reply #13 on: December 13, 2008, 02:43:04 PM »
i dont understand all the fuss, next time the car starts acting up, take the pipe that leads from the pump to the carb off, and have someone start the car, if you get fuel in your face it works, if not, you found your problem  ;D
fightingtorque
Re: power loss
« Reply #14 on: December 14, 2008, 11:03:15 PM »
the situation where the power gets worse as you try to open the throttle more is a symptom of a poor fuel pump and I had this on mine,  But if when you get to the floor it suddenly goes, then that is different.  When you floor it you bring in the second barrel/choke of the carb.  Maybe you have a blockage on the primary, or maybe you are suffering from carburettor icing?  have you tried moving the flap on the airbox across so that it picks up the hot air from the exhaust rather than the cold air?
