Author Topic: Warning light coming on - Can anyone help?  (Read 2076 times)
chrisrhodesinlbz
« on: December 10, 2008, 08:42:54 PM »
A warning light has started to come on in my Bis. I don't have a handbook so am not really sure what it actually means  :-\
It is in the top left hand part of the instrument panel, and shows what appears to be a radiator and a fan. The car is not overheating at all, it is not on all the time. It has only showed at night, when the lights are on, and flickers red when I brake and change gear.
What does it mean, hope a forum member can tell me.
Re: Warning light coming on - Can anyone help?
« Reply #1 on: December 10, 2008, 08:51:51 PM »
Hy chris. this ligt is the low coolant level light, so you must be on the line, so when the water mowes just a little, the float drops and the bulb flashes... recommend you add some water and see what happens,,,  ;)
« Reply #2 on: December 10, 2008, 08:55:04 PM »
This might help.
« Last Edit: December 11, 2008, 09:18:11 AM by ChrisRLewis »
« Reply #3 on: December 10, 2008, 09:10:20 PM »
if you pm me your address i will endevour to find a manual you can have .mick
chrisrhodesinlbz
« Reply #4 on: December 11, 2008, 09:22:31 PM »
Many thanks Gordan, Pete and Mick
It seems so obvious now  :o ! I went to Halfords tonight and it was closed, and ended up buying the world's most expensive antifreeze in an Esso garage, filled up 'Bubble' and went for a spin and no more lights coming on. I am very relieved, i thought it was something more sinister! I hadn't even noticed that light had existed before.
Many thanks for your help!
« Reply #5 on: December 11, 2008, 09:33:08 PM »
OH NO!!! NOT THE DREADED HALFRAUDS!!!! LOL
Ps: no swearing on the forum please..  :P
« Reply #6 on: December 12, 2008, 11:40:00 PM »
do yourself a favour and go into said shop and ask for a trade card you will then refrain from using that comment when you realise how much you save on stuff, trust me .
