Author Topic: Pink Powder Puff vs Power Tools!!!  (Read 26735 times)
Re: Pink Powder Puff vs Power Tools!!!
« Reply #60 on: January 06, 2009, 02:10:07 PM »
Be carefull cutting away, some go too far:-
« Reply #61 on: January 08, 2009, 08:15:49 PM »
sills look solid enough..  ;D
« Reply #62 on: January 08, 2009, 10:03:09 PM »
who cares about the looks, i bet that engine still hasnt got more than a few hundred kms on it :P
« Reply #63 on: January 16, 2009, 05:00:59 PM »
got the fibre glass now, so im filling the holes up, and making those 1'' extra wide arches!!!
« Reply #64 on: January 21, 2009, 04:12:51 PM »
had a quick do on my inside
« Reply #65 on: January 21, 2009, 04:24:47 PM »
this is my bed room full of bits just waiting to go in, when that damm weldings done!!!   >:(
nathan126
« Reply #66 on: January 21, 2009, 04:46:25 PM »
Dude! you have the same gearknob as me!  8)
mines only on there to save the original..
steering wheel looks good fitted  [-/
« Reply #67 on: January 22, 2009, 12:20:34 PM »
yeah, i only paid about a pound for it. going to get one of those abarth ones on ebay for it.
« Reply #68 on: January 22, 2009, 12:47:49 PM »
oil coolers are easy to fit, you need the timing cover machined out to take the return feed, the ones from italy for the aircooled have an adapter to take a spin on filter too....the feed out the block is straight forward too
the above info is for aircooled engines...a complete kit is availible for the a/c cars..... i would say its a great help, also fit a larger sump...dont forget cars are cooled by oil too......
i like the mesh rear panel......buzz 1 and 2 nearly had that, in the end i went for a split and raised boot lid with oil cooler mounted in the out going air stream.....my boot lid was powered so i could warm her up easier.....then with a press of a button the lid would raise.....
as a foot note....my 850 abarth studies show a small but wide water radiator mounted under and to the front of the gearbox.......i wonder if bis's would benifit from this mod?.............bis owners should study the abarth modifications to the 600 and 850 cars to aid cooling.....some good tips there....
« Reply #69 on: January 22, 2009, 12:50:50 PM »
thanks dave, ill look into it
« Reply #70 on: January 24, 2009, 12:51:23 AM »
a few pics...
« Reply #71 on: January 24, 2009, 12:53:52 AM »
go on one more
« Reply #72 on: January 24, 2009, 11:52:26 AM »
are you re carpeting the whole car or just theese bits? i thought aluminum plates would better suit a rally car  :P
« Reply #73 on: January 24, 2009, 02:42:56 PM »
just doing a few bits... not decided yet?
« Reply #74 on: January 29, 2009, 05:03:57 PM »
body kit is next on list and mold them onto 1'' wider arches.. just cutting the old bumper up to fit.. long way to go tho..
