Author Topic: Cylinder Head Repair  (Read 3430 times)
custardboy
« on: December 02, 2008, 08:04:13 AM »
Finally removed my aircooled's engine and stripped the top down to confirm suspected blown head gasket.
Head is a bit coked but not too bad.
Plenty of bolt breakage and managed to strip the threads in the head removing 2 bolts from exhaust manifolds.
Anyway, I know I should probably get head skimmed before rebuilding and I thought to get hardened valves and seats fitted would be good idea too.  However, I am strugling to find an engine reconditioners or engineers around Nottingham who will do the work.  I soon as I say Fiat 126 they don't want to know I don't understand whats so special about it, unless its too small a job?
Anyone have experience of having this done, anywhere?
custardboy
Re: Cylinder Head Repair
« Reply #1 on: December 02, 2008, 08:24:17 AM »
Have a ring round some of your local motorbike shops, They may know someone who specializes in skimming small heads.
custardboy
« Reply #2 on: December 02, 2008, 08:53:56 AM »
Thanks.  I have seen that Ricambi on ebay have unleaded recon heads but they're over 300 quid and anyway I hate wasting what I've already got.
« Reply #3 on: December 02, 2008, 09:17:45 AM »
Have you checked that the head actualy needs skimming or were you looking raise the compression as well. I got all the tools & parts (helicoils) to repair stripped threads fairly cheaply on eBay. Those threads are M8 x 1.25 mms. For unleaded you only need to replace the valve seats , the valves are OK. I got a head done for £58 at a place in Watford but that is a bit off your patch.
custardboy
« Reply #4 on: December 02, 2008, 09:38:41 AM »
I have the necessary to repair the stripped threads and no I'm not certain the head needs skimming, thats only what I was advised previously.
In fact I have never had to get a head skimmed and have done head gaskets on Rover V8's and Triumph 6 and many others.
I am dusbious about having the head skimmed as if you take too much off, quite apart from altering the compression you would loose the exhaust gas escape channel.
I have some more food for thought, cheers.
custardboy
« Reply #5 on: December 02, 2008, 09:56:17 AM »
A good way to check if the head needs skimming is to get a plate of glass. Apply valve grinding compound onto the glass face. Rotate the cylinder head face on the glass (all directions) after a while you will see the high and low spots. Keep going and it will level off if it's a light bow. I did this to my old citroen ax diesel (alloy head) after an hour it was perfect and a better finish than the machine shop. But remember to give the head a good clean to get rid of all traces of the compound.
But if you are getting the valve seats done I would get the machine shop to do the seats and the resurfacing at the same time.
custardboy
« Reply #6 on: December 05, 2008, 08:12:11 AM »
Well the cylinder head doesn't require skimming but as I couldn't extract the broken exhaust manifold bolt I had to give it to a specialist who deals with motorcycle engines, they are going to repair it for me and convert for unleaded 100 quid all in, but won't be ready until after Christmas!
I found my exhaust was full of holes so need a replacement, wonder whether to fit a sports type or keep to standard as the engine has no performance modifications, would it help or hinder?
Plenty of time to do other jobs but am already fretting without my 126 to drive :'(
« Reply #7 on: December 05, 2008, 07:01:34 PM »
Unless your going all the way with a performance cam, 40 weber and larger inlet/exhaust valves, stick with the standard exhaust its a good compromise for power, torque and economy plus its alot cheaper to buy, Even with all those mods it will only give you an extra 10 to 15 bhp of unreliable power, you can always weld a bigger pipe on the exhaust box  ;D ;D
« Last Edit: December 05, 2008, 07:19:35 PM by Pete126 »
custardboy
« Reply #8 on: December 05, 2008, 07:36:05 PM »
Thank you Pete126 thats the advice I was after, I will order and standard exhaust, ready for when I get cylinder head back.
« Reply #9 on: December 12, 2008, 04:58:21 PM »
Better still if you can find a mirror. the glass used in mirrors is optically very accurate and will give a greater gaurantee of flatness
custardboy
« Reply #10 on: January 12, 2009, 08:35:13 AM »
Thanks for all the advice - I now have my baby back, well almost.  I got the cylinder head back from SEP in Kegworth, good job done too.  I spent couple of hours Friday evening and most of saturday rebuilding the engine and putting it back into car - I had few problems especially with new exhaust and manifolds and the air was blue for much of the time.  Set the valves and timing and it fired up once fuel had pumped through.  Runs much better now, though haven't ventured out for run yet to really test.  I just hope my hot starting problems are cured as well.  All nuts and bolts accounted for which is amazing as I usually end up with some spares! 8)
