1st check for spark by getting an old plug, let it rest against the engine somewhere and crank, if there is spark it wont be points.
2nd check for petrol, simply pull the pipe off the carb, crank and see if petrol comes out.
If these two are there it should run.
There is also a possibility that the slow running irregularities could have been a flooding float level issue.
Signs of that is sooty or wet plugs.
The way I do my timing is both pistons go up and down at the same time.
When the pistons are at top dead Centre (TDC) the rotor arm will be pointing at either 1 or 2.
If it is pointing at 1 the valves on piston 2 will be 'rocking', it should start and a timing light will precisely set the ignition.
Bearing in mind it was running I think you have an issue with fuel or spark.
My bet is on fuel and flooding and would try cleaning the carb with special attention paid to the needle and seat. I'd also fot a fuel filter or replace if one is already fitted.
