Author Topic: Bis Service  (Read 1460 times)
finlay
Bis Service
« on: November 18, 2008, 08:12:47 AM »
Well my wee car is almost ready for the road.  I do need to change oil, plugs etc first though.
Can you remind me what type of plugs are best please?  Also regarding oil change what grade and volume do I need, lastly dont think the car has an oil filter?
Is it an idea to change the coolant also - been probs ten years since that was last done.  If so what are the tips for draining and refilling?
many thanks
Bis Service
« Reply #1 on: November 18, 2008, 11:24:16 AM »
just remember if you change the oil to clean out the centrafugal oil filter if you havent before, and make sure after filling the coolant that you bleed the system (little tap under front bonnet).
finlay
Bis Service
« Reply #2 on: November 18, 2008, 07:14:05 PM »
Thanks!  OK idiot question - whats the easiest way to get at the filter?
Also an recommendations for plugs?
Bis Service
« Reply #3 on: November 22, 2008, 10:26:36 AM »
you have to take the rear panel off. two bolts on either side, support the engine by either a jack underneath or a brace from above, and undo the engine mounting ( theres a hole by the boot latch covered by a rubber grommet remove that to get access to the bolt ) the remove the hole panel complete with bumper. its a bit of a game just to clean the filter which is why nobody ever did when they were new so expect it to be well gummed up with crap. dig it out with a screw driver or a scraper then wash it with petrol and your bis will love you  :D
