Author Topic: petrol filler problem  (Read 1651 times)
kerry
« on: November 18, 2008, 07:07:34 AM »
every time i go to fill up the car, the pump cuts out immediately, as though it's full, even when it's empty. quite irritating as it takes ages to fill up and then when it does eventually fill up full, it comes pouring out, of course.
does anyone else have this problem?
it's a Bis, BTW.
thanks all.
« Reply #1 on: November 18, 2008, 07:36:13 AM »
its cos the pump cuts out cos the fuel isnt coming out of the pipe cos its hitting the back of your filler neck, pull the pump nozzle out a little, takes practise but with some experimentation to get it in the right place youll find you can get the fuel to flow, my bmw does it as well as the fiat...
as for the squirting out when its full you need to learn how much fills it then slow down when youre at the top..... :wink:
phreak97
  • Niki!
« Reply #2 on: November 18, 2008, 09:56:44 AM »
yeah, try tilting the nozzle up and down too, the cutoff sensor is at the top of the opening at the end (here anyway, have a look at the end of the nozzle next time, therell be a little hole in the top or bottom), you need to try to make any splash inside miss there.
phreak97
kerry
« Reply #3 on: November 18, 2008, 09:17:34 PM »
thanks guys. I'll try again next time. I thought I'd tried every angle and position, but you never know...
phreak97
  • Niki!
« Reply #4 on: November 19, 2008, 09:46:55 AM »
otherwise you might have to live with not pulling the lever the whole way, some cars simply dont let the fuel run into the tank as fast as it comes out of the pump. i've found it varies depending on the pump, some work better than others, even different ones at the same petrol station.
phreak97
« Reply #5 on: November 19, 2008, 10:41:06 PM »
ive tried it at ever angle and position too ... but ive never had any problem getting such a small nozzle into such a big hole.....and the petrol pump thing too.lol
