Author Topic: BREAKDOWN!!!  (Read 1589 times)
BREAKDOWN!!!
« on: November 17, 2008, 03:21:09 PM »
Right chaps, alan (yes I gave the car a name) decided he wanted to come home on a low loader on friday night, now I have traced the problem to the ignition circuit, Ive replaced the points (no effect) I was wonder if there is any way I can bench test the condensor and coil pack to sus out what the problem is?
BREAKDOWN!!!
« Reply #1 on: November 18, 2008, 06:59:28 AM »
what did it do ? when it broke down. and have you looked at the normal places of wear on the loom? passenger wheelarch ,under rear bench?  have you got power going to your coil?
BREAKDOWN!!!
« Reply #2 on: November 18, 2008, 07:23:22 AM »
It was missing slightly and I pulled in to check it out and then it refused to start and at the moment its backfiring but I'll check em out the loom and the coil
phreak97
  • Niki!
BREAKDOWN!!!
« Reply #3 on: November 18, 2008, 09:39:23 AM »
that sounds like what happened when our point gap closed up.. but you said you've done the points.  check theres power to the coil (probably about 8v).
is it possible your distributor nut came loose? itf your timing is way out it would cause the engine to run pretty unhappily.
phreak97
BREAKDOWN!!!
« Reply #4 on: November 19, 2008, 02:41:18 PM »
turned out to be the condensor (I had already repaired it once but the wire busted again) so he's firing on all 2 cylinders and raring to go!!!! many thanks to all for you advice!!!
