Author Topic: Indicators - unreliable..  (Read 2196 times)
ollieG
« on: November 09, 2008, 12:58:34 PM »
My indicators are getting temperamental! They worked fine a few weeks ago but started getting erratic recently. The timing between flashes is irregular and now sometimes they don't work at all... but other times, they're OK.  Sometimes when it's really wet, the dash indicator light stays on, not flashing, even though I can see the exterior indicators flashing normally.
Very strange...
Is it just that the repeater needs replacing?...dodgy connections? Any clues anyone?
Thanks, Ollie.
« Reply #1 on: November 09, 2008, 02:17:59 PM »
had the same problems I replaced all the connectors on the from and sides and cleand the curcuit boads on the rears this seemed to resolve the issues.
« Reply #2 on: November 10, 2008, 12:21:03 PM »
first try changing your flasher unit , if that does nothing then go round and clean all connections as stated above . touch wood its your flasher unit.
ollieG
« Reply #3 on: November 13, 2008, 08:56:54 AM »
Thanks for the replies...unfortunately I think it's a bit more than the flasher unit and connections. A couple of days after I posted, the car died altogther with a flat battery...still trying to find out exactly what the problem is.
« Reply #4 on: November 13, 2008, 11:30:09 AM »
in that case check your alternator as it could be just a low/flat battery was making your blinkers go slow as the car was running off the battery and not the alternator.
phreak97
  • Niki!
« Reply #5 on: November 18, 2008, 01:09:52 PM »
same thing happened to me, in the end it was the alternator not switching on due to the battery light in the dash having a bad connection. when you turn your key to the on position (dont start it) does the battery light come on? it should come on, then go off again when you start the engine.
phreak97
« Reply #6 on: November 18, 2008, 01:17:41 PM »
just something to point out if you have problems with the drivers side rear lights remember to check behind the other rear light unit as the loom travels down one side then branches off from this other unit to the right hand side , i have had a couple of problems in the past due to the connections on the nearside unit .
ollieG
« Reply #7 on: November 20, 2008, 10:20:38 AM »
Cheers all..the dash battery light does come on when I turn the key. I'm pretty sure the alternator is shot. There were some dodgy cables that were a bit loose into the alternator which I fixed but the problem remains. The car would jump start but keep dying after a few seconds. I just think I need a new alternator. Now I'm looking for the best deal... Perhaps one of the Club 126 members has one I could buy. Thanks again for your help.
« Reply #8 on: November 20, 2008, 11:17:12 AM »
have you made sure that your coil is working , checked your points and  ht leads and change the condensor ?
phreak97
  • Niki!
« Reply #9 on: November 21, 2008, 01:58:11 AM »
also make sure theres actually water in your battery, i had one that dried out and died.
i dont think the alternator can die and still turn off the dash light when the engine starts. but i could be wrong.
phreak97
