Author Topic: bis exhaust wanted  (Read 1616 times)
joda
bis exhaust wanted
« on: November 07, 2008, 12:14:05 PM »
as above, mine seems to have bust where the manifold goes int the main box, happened a few times now so patching patches, time for a new one!
 sporty thing prefered, but standard will do
126Bis
ollieG
bis exhaust wanted
« Reply #1 on: November 13, 2008, 10:02:08 AM »
Hi Joda,
If you can give me til early next week I may have a standard exhaust with brackets for you. It's used but literally only for about 1 month. My BIS may well have terminal electrical problems and if that's the case, I'll get it scrapped. I'd be happy to sell you the exhaust for a reasonable price if you still need it. Will let you know...
Cheers, Ollie.
bis exhaust wanted
« Reply #2 on: November 13, 2008, 04:32:33 PM »
terminal electrical problems!!!!
What?
joda
bis exhaust wanted
« Reply #3 on: November 17, 2008, 12:56:31 PM »
Quote from: "ollieG"
Hi Joda,
Cheers, Ollie.
sounds good, keep me posted ! :)
126Bis
ollieG
bis exhaust wanted
« Reply #4 on: November 20, 2008, 10:40:36 AM »
Hey Joda, I think I've found a solution to my electrical problems so the car can stay on the road. Sorry about that - I hope you can find an exhaust. What I can say is that when you get a new exhaust make sure you know whether you have the front and rear attachment brackets or not. There are two types of exhaust so if you don't have the brackets, you will need to get the newer exhaust type which has the attachment flange pre-welded. OR find brackets and use the older style exhaust.  The exhaust I replaced was the newer type with pre-welded flanges and never fit properly so it rattled about and was a nightmare. Its poor fit eventually lead to its destruction! I would recommend using the 'bracket' attachment approach. If you don't have brackets they aren't all that cheap but probably will be worth it in the long run as I think the old style exhaust might be a bit cheaper and easier to find anyway. For brackets try https://ssl.kundenserver.de/shop.fiat500126.de/indexa.htm or you could try emailing Jan at [email protected] - that's where I got my brackets for £20 a set. Ricambio is an easy place to get an exhaust but you pay top whack for it and make sure you know which style of exhaust you're getting if you buy from them. All the best and hope you get it sorted. Ollie.
