Author Topic: Points question  (Read 1567 times)
rockchevy85
    • http://myweb.tiscali.co.uk/camaro/bambi
Points question
« on: November 02, 2008, 04:15:29 PM »
Hi all
The points on our 126 seem to be adjusting themselves closed of late. I've noticed a few bolts on this car are shaking themselves loose, but is this normal? I don't imagine a 2 cylinder engine will ever run smoothly but is this right? I am tempted to glue them in...
I bought a new set of points on Ebay but they are not correct. This first picture shows the original ones and the second picture shows the new ones. Circle 1 shows a difference in the adjustment (or to put another way, the new ones don't HAVE an adjustment). Also, circle 2 shows a fastening I've not come across before. I was unable to remove it without sawing it off, is there a technique I'm missing or do I have to buy the complete points carriage? Any supplier information would be greatly appreciated if the latter is true.
Regards,
Simon
Points question
« Reply #1 on: November 02, 2008, 08:01:29 PM »
There are two types of distributors, Magnetti marelli, and polish Zelmots, the two are different, and i made the same mistake as you, but the man in the shop gladly replaced mine. Find out which ones you have and get the correct type...  :wink:
p.s. your 126 is a bis, right?
rockchevy85
Points question
« Reply #2 on: November 03, 2008, 09:50:11 AM »
Thanks for the reply.
Yes, mine's a BIS. I just checked the distributor and the cap says "Magnetti Marelli", so I guess that answers that question. I take it the Magnetti Marelli breaker set is the complete carriage with adjuster screw and points all pre-assembled then? I can't see any way of getting that fastener off without breaking it.
Regards
Simon
Points question
« Reply #3 on: November 03, 2008, 03:10:23 PM »
acutally.. there are 3 types of marelli BIS points..
1-the early 2 part type
2 the cassette type (what you had)
3 the cassette refurb kit (which is what I suspect you are trying to replace you old ones with)
in you points kit you should have a circlip and a new pin to mount the bit you have photograhphed above you need to remove the cassete grind through the rivit that holds it in, replace the points part and fix it in place with the pit and the circlip
im getting a new set tommorow so I'll to a photo work through of how to do it.
Points question
« Reply #4 on: November 03, 2008, 03:36:54 PM »
Im afraid cant help you any more than stuey, i have the Zelmot type...
