Author Topic: Head gasket change help  (Read 1691 times)
c4nutter
« on: October 25, 2008, 03:23:01 PM »
Hello all
My name is James and i have a fiat 126 BIS.
We recently had the head gasket go on the car and have now replaced it. But i cant get the engine running again. Im what your call a have a go mechanic not an expert so forgive me for my attempt at an expanation.
When i turn the engine it sound s like its turning over as normal and then clunks. like this...
nurrrrr nurrrrr nurrrr clunk nurrrrr nurrrrr nurrrr clunk.
and the occassional pop from the exhausrt
any ideas anyone ? please ?
« Reply #1 on: October 25, 2008, 05:31:00 PM »
Welcome to the forum james, ets see if we can help,
its either a knackered starting system in some respect or something mechanical is preventing the engine from turning over..
firstly is the battery well charged- the clunk sounds like the battery doesnt have enough juice to keep it going?
If this isnt the problem  does the engine turn over freely? (Ie if you put it in gear and push it backwards and fowards does the engine turn over with out hitting anything- its may be easier to take the spark plugs out for this?)
its worth checking all the basics ie- are you getting fuel/spark/timing/valve clearences.. if you dont know how to these just ask.
cheers stuey.
phreak97
  • Niki!
« Reply #2 on: October 26, 2008, 03:38:02 PM »
Hi, I'm James also:P
as for your problem..
have you got the push rods and tappets all seated happily?
make sure the rocker cover isnt hitting the tappets, this can happen if the gasket is missing or the nuts are overtightened and it can stop the car from starting.
phreak97
