Author Topic: Doing the Tappets on my Bis  (Read 2993 times)
jumpinjacks
    • http://www.jumpin-jacks.co.uk
« on: October 23, 2008, 01:11:43 PM »
I need to do the tappets on my Bis, and I know what the clearances should be as I have checked the workshop manual and how to adjust. But what I need to know, is when do I adjust them? I heard from someone that it has to be on cam to set two of them up and then move the car and setup the other two. Is this right?
If so, how do I know when its on cam and which two should I do when it is?
Fiat 126 Bis Owner
« Reply #1 on: October 23, 2008, 07:58:25 PM »
Use the rule of five:
.When number 1 valve is fully compressed adjust number 4
-----------------2 ---------------------------------------------- 3
-----------------3 ---------------------------------------------- 2
-----------------4 ---------------------------------------------- 1
as you can see each line adds up to five. P.S. The engine easier to turn with the plugs out.  :)
jumpinjacks
« Reply #2 on: October 23, 2008, 10:16:29 PM »
Which side is number 1 on a 126?
Fiat 126 Bis Owner
« Reply #3 on: October 23, 2008, 10:40:45 PM »
1 starts at the back of the car running forwards i think (not that it should matter as they are siamised anyway if the back one is fully in do the front one and whichever middle one is fully in do the other middle one etc....
« Reply #4 on: October 23, 2008, 11:31:56 PM »
does'nt matter which way round you number the valves front to back or back to front  :)
« Reply #5 on: October 24, 2008, 12:22:22 AM »
would labelling them alphabettically mess this system up?..
« Reply #6 on: October 24, 2008, 08:24:41 AM »
I was thinking some colours and geometrics shapes?
say-
.When -------- red circle is compressed adjust  blue triangle
-----------------yellow star ----------------------- green hexagon
    -----------------green hexagon ----------------- yellow star
        -----------------blue triangle --------------------- red circle
jumpinjacks
« Reply #7 on: October 24, 2008, 11:28:53 AM »
I take it when you say compressed, you mean fully compressed so that I can't even get a feeler guage in there?
Fiat 126 Bis Owner
« Reply #8 on: October 24, 2008, 11:49:54 AM »
the tappet should be pushing down on the top of the valve as far as it can.
phreak97
  • Niki!
« Reply #9 on: October 24, 2008, 01:42:56 PM »
if you take the spark plugs out and take the car out of gear you should be able to turn the engine by hand if you put a little effort in (instead of rolling the car along). if you turn it over a few times youll get the feel of what the tappets do. you basically just want to adjust them when theyre in their neutral (doing nothing) position. you dont have to do it at exactly the right spot relative to the others or anything, you just have to make sure each one you adjust hasnt moved from it's neutral position yet.
phreak97
jumpinjacks
« Reply #10 on: October 24, 2008, 06:18:29 PM »
All done now, thanks for the advice guys  :) Good Karmas will be given.
Fiat 126 Bis Owner
Re: Doing the Tappets on my Bis
« Reply #11 on: January 05, 2009, 06:12:12 PM »
useful thread, recommend a sticky... ;)
(just needed to know this myself)
« Reply #12 on: January 06, 2009, 01:24:15 PM »
Easier to explain with pictures :) With every engine, this is how you number them, no matter what direction it sits in the engine bay.Note: don't confuse boxer engines to straight engines like in the BIS. It's still a straight engine no matter how many degrees the whole cylinder block is turned. The numbering goes in the direction of where the torque 'leaves' the crankshaft (i.e. where the gearbox is).
