Author Topic: We Went Nikiing (a short holiday)  (Read 2032 times)
phreak97
  • Niki!
« on: October 13, 2008, 02:32:42 PM »
Today my friend and I returned from a holiday on kangaroo island (couple of hours from here to the ferry terminal, 45 mins on the ferry, then half an hour drive on the island to my friend's dad's place).
We drove my niki over there for the KI Motorfest, which turned out to be relatively small, but was still fun.
my car was easily the smallest one there, and i got lots of comments.
we went on a little run around kingscote, then assembled at the golf club there.
while over there we did lots of driving around on dirt roads at up to 110km/h, the corrugations made the car all floaty feeling:P managed to do a bit of very low speed niki drifting (didnt want to hurt niki) in a couple of places, the roads are very loose gravelly stuff, i could even spin the wheels in a straight line.. seemed like a pretty unsafe choice of road material.
on the land opposite were we stayed, there were some wrecked cars, my friend knew the owner of the land and we went to enquire, i was interested in the vw kombi and the leyland mini motors (both bodies were ruined), he said we could have the mini motor but he'd need to ask some relative of his about the kombi.
anyway, he never got back to us about the kombi, but we spent all of yesterday getting the 1L engine out of the mini, we had a pretty standard set of tools, and no engine crane to get it out with, along with that the car was a pretty typical 10-year paddock wreck, LOTS of rust, thoroughly mangled from being moved around by a tractor or something, no wheels..
we used a big long pole to try to lever the car onto its side, but ended up with it half way, propped up by a tractor rim, and tied to the old fire truck that was next to it. kinda scary to work under, but i'm pretty sure it was secure..
anyway, we eventually got everything undone, and there unded up being four of us to pull it out (it was still really hard).
then the problem..
we were there in a niki, and there were two of us plus luggage.
but we managed!
my friend has photos of the whole thing packed up with me in the back and him in the front, ill try to get them and post them.
the engine will likely go into the morris 1100 i have here with no engine in it.. bit underpowered (just 1L, instead of 1.1), but it's free.
phreak97
« Reply #1 on: October 13, 2008, 03:49:22 PM »
:D  And room to spare :D  :D
« Reply #2 on: October 13, 2008, 04:20:22 PM »
Hmph... if it only was a bis... no such problems...  :P  :P  :D  :D
Anyways, seems you had a nice little adventure... cool...  :cool:
Normansinjunstevas
« Reply #3 on: October 13, 2008, 11:18:26 PM »
Streuth!
If you can get that old mini engine going, then you're more of a man than what I'll ever be.
Big Respect
Normski
phreak97
  • Niki!
« Reply #4 on: October 14, 2008, 01:55:54 AM »
haha, we didnt have much space to spare after we put our luggage in..
niki adventures are excellent. we went round to a few deserted beaches, helped out on a sheep farm (mostly just watched though), and went round visiting a few other people my friend knows on the island. we were only there for three nights, and we had a fairly limited budget, so we didnt do much in the way of touristy stuff.
i dont think the mini engine would have fit in the back of a bis.. not that i've ever seen one in person, but the engine as it was had the gear linkage housing less than an inch from stopping the door from closing, and whenever i changed from first to second i'd hit the oil filter.. it was a tight fit as it was.
as far as getting it running.. i have an 1100 engine with a con rod through the side.. so ill be nicking alot of bits from that.. carb, distributor, starter motor, generator, all mounting brackets, radiator, thermostat housing, clutch slave cyl, probably the whole clutch, rocker cover (the mini one has the breather pointing differently), probably all the gear under the rocker cover too, the diff, speedo drive, and gear linkage housing have got to be changed, the 1100 has different ones.. though i'm going to count the teeth on the diff before i decide to swap that.
the mini had only done 30,000 miles! and the oil on the dip stick had only a tiny bit of white on the top from the oil cap being missing.. it was still clean otherwise.
basically theres a fair bit of work to do, but i think it should work out well.
phreak97
« Reply #5 on: October 14, 2008, 07:04:17 AM »
With the back seats folded? Hm... i dont know... but that would be no fun now would it...  :D
You sure know your engines... as norman said: Big Respect!  :wink:
phreak97
  • Niki!
« Reply #6 on: October 14, 2008, 02:47:30 PM »
i didnt know bis seats folded.. lol. and youre right, it wouldnt have been much of a story to say "we put an engine in the back of the car and drove home, it fit easily"
i dont feel like i know that much, i still dont know the names for most of the bits inside a motor (hence just saying the gear under the rocker cover.. i have the parts in mind, but dont know the names).. i'm mostly self taught, which makes it hard to know the names of everything.
almost everything i know i've learned since may last year.. i've mainly had an electronics background before that.
assuming i get accepted, ill be doing a 6 month full time automotive course next year, so that should get me pretty set.
phreak97
Normansinjunstevas
« Reply #7 on: October 14, 2008, 03:50:27 PM »
My son.
I'm sure you'll do really well on the course, judging by what we've seen of your manly approach to mechanical problems.
Best of British Luck to you!
Norman
phreak97
  • Niki!
« Reply #8 on: October 14, 2008, 11:25:56 PM »
thanks for the vote of confidence:) now i just gotta get through the impossibly complex application process.
phreak97
