Author Topic: Speed/gear  (Read 2879 times)
Speed/gear
« on: October 08, 2008, 10:36:10 PM »
Heres a question for all you BIS owners. At what speed do you change to which gear.
The manual states:
1. - 34
2. - 53
3. - 84.5
4. - 116
(this is with 2 pesons and 20kg of luggage...)
 while with my car its more like
1. - 20
2. - 40
3. - 65
4. - never taken it to the max...
(me alone... after these speeds the noise becomes wery loud and you have to change gears..)
this is all in km/h
id be grateful for your info cos either my engine is pretty messed up, or they are lying in the manual...
thx.. giordano... :wink:
Speed/gear
« Reply #1 on: October 09, 2008, 07:19:24 AM »
sounds about right (maybe a tiny bit under powered) mine tops out at 104km/h 65mph in 4th (this is by gps)
nathan126
Speed/gear
« Reply #2 on: October 09, 2008, 05:59:48 PM »
No idea about kph, but usually for consumption:
1st - 2nd - roughly 10mph
2nd - 3rd - about 20 - 25
3rd - 4th - anywhere between 30mph and 40.
Although it depends how fast i wanna go, and how many hills there are  :wink:
Never pushed to the max, i think i went about 60mph.. although on the island it's very hard to go any faster
Speed/gear
« Reply #3 on: October 09, 2008, 06:22:11 PM »
Cheers guys..
Nathan, you seam to have pretty much the same performance as me...
by the way 1 miles = 1.609344 kilometers  :wink:
p.s. a rookie question here--- what mekes the engine loose power over time? Bad compression?
nathan126
Speed/gear
« Reply #4 on: October 09, 2008, 07:27:56 PM »
I've never really seen what she can do to be honest, i do admit she needs a good service though.. im not so keen on the local garage, they tried to open the front boot to get to the engine?  :lol:
Speed/gear
« Reply #5 on: October 09, 2008, 08:04:37 PM »
Yeah i hear you, i dont like pushing the car either, most of the time i drive 60km/h in 4 gear (about 40mph) the engine runs smoothly and quietly and the consumption is low...
Speed/gear
« Reply #6 on: October 10, 2008, 09:23:22 PM »
Blimey!
I've had my bis up to 85mph...I must be the hooligan in the crowd  :twisted:
Speed/gear
« Reply #7 on: October 11, 2008, 06:53:40 AM »
And then you probably had to stop for 15 mins for the engine to cool down...  :roll:  :roll:  :D
Speed/gear
« Reply #8 on: October 17, 2008, 04:13:33 PM »
Lose power over time, as in km's made, or rpm wise? Well, over time, the moving parts wear away. Tolernces aren't the same as new, and yes the main problem is loss of compression. The piston rings wear away, so the mixture isn't compressed as what it should be. The engine burns more oil, and the fuel consumption rises (the air fuel mixture 'escapes' into the sump for e.g., not all of the exhaust fumes leave via the exhaust valve, but end up in the sump as well, which cause the engine to smoke like a kettle when the sump ventilation pipe is taken off). The valve seats wear, which also leads to loss in compression. Then there's the ignition, and carbie problems which also lead to loss in power.
RPM wise, all engines have a max. torque and max. power output that they can supply at a certain rpm.
Speed/gear
« Reply #9 on: October 17, 2008, 05:17:51 PM »
Quote from: "GTMaster"
Paints a bleak picture  :cry:
My car is in the process of this decline as we speak, but I'm sure it will last until they ban the internal combustion engine on the UK roads. probably the not too distant future then...
Speed/gear
« Reply #10 on: October 17, 2008, 05:24:29 PM »
Cheers GTMaster, Karma +  :wink:
Speed/gear
« Reply #11 on: October 17, 2008, 11:24:17 PM »
PS my BIS never overheated once  :cool:
But I've revised my attitude toward speed with the air cooled.
She definitely doesnt like going very fast, might be that I have to tinker a bit more. Going to get a strobe light soon to set the timing a little better than by ear.
1st is so noisy I litterally just get the wheels rolling then it's into second.
Air cooled heaters rock! Not even off the estate and the warm air is blowing through! It's great!
The BIS heater is great but takes longer to heat up.
One downside to the aircooled is that any smells in the engine end up in the car.
I learned this the hard way from a weeping rocker cover gasket. The oil burns in the head/exhaust and fills the car with burning smells and fumes  :sad:
The wife bleated so much that we ended up tolerating the cold...
Normansinjunstevas
Speed/gear
« Reply #12 on: October 18, 2008, 08:08:37 AM »
Darrell, my son.
At least your wife doesn't mind driving about in your 126.....mine wouldn't be seen dead in mine. She effing hates it.
This I find ironic, as she drives about in some poxy Renault Scenic.
"Women!.......Can't live with 'em....Can't shoot 'em"
Yours Misogynistically
Normanovitch
Speed/gear
« Reply #13 on: October 19, 2008, 08:51:32 PM »
Hehe yeah I have a neice like that who wont be seen in a 126.
Luckily my wife is a bit of a hippy / hillbilly so she loves the 126.
In two weeks we have gone through 4 tanks of fuel, we're really using the 126 alot and enjoying it.
One thing worries me is my fuel consumption seems to be noticably worse at anything above 50mph. :cry:
But the little air cooled is proving so reliable.
