Author Topic: will a bis fuel pump fit an aircooled?  (Read 2463 times)
phreak97
  • Niki!
« on: October 07, 2008, 03:04:19 PM »
basically, i can get a bis fuel pump for cheaper than an aircooled one.. it looks like it has an extra line coming off it, so i expect it wont be a direct swap as far as the lines, but will it bolt straight on and work?
otherwise, what other cars use a fuel pump that will fit a 650 engine? 126 bits are a bit hard to find here.
thanks
phreak97
« Reply #1 on: October 07, 2008, 04:03:15 PM »
the bis fuel pump has a pipe from the tank to the pump, from the pump to the carb, and a fuel return pipe... hope this helps at all... dont know much about aircooleds... :wink:
phreak97
  • Niki!
« Reply #2 on: October 08, 2008, 02:40:26 AM »
well, it sounds like it could be made to work if i blocked off one of the returns (the aircooled has one from the carb) or connected them together then back to the tank. but what i really need to know is if it will bolt straight on and work (same travel distance etc)
phreak97
« Reply #3 on: November 11, 2008, 12:15:33 PM »
Bis pump is run by a rod and has a small bit sticking out the pump.
Air cooled has a lever which is a big longer bit sticking out the pump which pushed directly onto the cam.
In my opinion spend the money and get the right pump.
Might be able to switch the bit sticking out but more hassle than it is worth.
Most pump problems with the BIS is the rod wears and is not long enough to operate the pump.
phreak97
  • Niki!
« Reply #4 on: November 11, 2008, 01:11:09 PM »
yeah, i've been given a couple of fuel pumps that arent working, one is a leaky gasket, and i dont know what the problem is with the other one, but ill have a go at them and should hopefully be able to come up with one working one at least between the two.
phreak97
« Reply #5 on: November 11, 2008, 06:47:54 PM »
Better still is to change over to an electric pump, I fitted one to mine and it makes a big difference, Starts on the first turn of the engine, The Lucas/SU pump off a Classic Mini works well, or any low pressure electric pump upto around 5lb pressure  :)
« Reply #6 on: November 11, 2008, 08:03:11 PM »
Pete, would you mind elaborating how this el. pump works, im interested in gettin one, but i dont want anything toocomplicated... thx...
« Reply #7 on: November 11, 2008, 09:11:02 PM »
to fit a electric fuel pump is easy , remove the mechanical pump and block off the hole using a masking plate (make it yourself, v easy). fit electric pump in suitable place and wire up fit pipes to pump and carb/tank and off you go . i used a facet solid state pump , i have a seperate fuel switch to turn the pump on  it makes it easier to fit as you dont need to connect up  the ignition system also it prevents thieves getting far with your car before it conks out!! (also remember to fit a non return valve so that the fuel doesnt run back into the tank.)
phreak97
  • Niki!
« Reply #8 on: November 12, 2008, 12:51:47 AM »
yeah, i have a niki with an electric fuel pump already, but it looks like electric ones are pretty expensive anyway, if i can get a mechanical one for the same price, i will.
phreak97
« Reply #9 on: November 12, 2008, 06:01:08 AM »
Thanx bis13, didnt know it was that easy, if i knew i never would have gotten a new mechanical one... so i take it these are universal pumps i should be after... any specs i should be avare of?
« Reply #10 on: November 12, 2008, 08:00:34 AM »
This is the way I have wired the Pump in :)
