Author Topic: Piston Seal  (Read 1857 times)
Piston Seal
« on: October 03, 2008, 05:03:11 PM »
Is this stuff any good
http://cgi.ebay.co.uk/HOLTS-PISTON-SEAL-100g_W0QQitemZ160284444451QQcmdZViewItem?hash=item160284444451&_trkparms=72%3A1350|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
I'm pretty sure it is always much better to get to the bottom of a problem and fix it rather than this kind of temporary fix. But was just wondering if any of you have used it and whether it can be used as a sneaky little way of upping the compression a tiny bit. There is no doubt that my rings/valves/head and pistons are slightly worn, I'm just curious as to whether this sort of thing can actually work.
Piston Seal
« Reply #1 on: October 05, 2008, 09:58:27 PM »
well it says only use on worn engines , question is you only know if its worn by taking it apart? so surely that makes this a load of bollock5.also it says its not a permanent repair so does that mean it might get you home..just? i think it would be a gamble to try it but if your engine is well and truely shagged why not give it a go just for the fun of it?
Piston Seal
« Reply #2 on: October 06, 2008, 09:53:31 AM »
It's apparently what a lot of people stick in their dodgy motor before selling it, so it drives fine on the test drive and for a while after that, before the worn piston rings etc. reveal themselves again. Might just try it in the fiesta and see what happens - it's burning  a lot of oil at the moment.
